Yeah, yeah... The PCB is a prototype and I will test the possibility to drive LEDs only by PG signal and pull-up anyway when DC converter ICs arrive. Just want to have prepared backup pads and traces for MOSFET contraption already in place in case if LEDs can't be driven directly like that.
Maybe smart guys above can throw an idea how to drive a input voltage (12V or 24V in random possibility) presence LED with minimal component count and keep the same brightness? A single resistor (SMD 0603) end with a very dimly lit LED or resistor itself warm up to +40..50C degrees. Of course there are constant current drivers for LEDs like NCR402U, NCR402T, BCR402R etc. But these will be another overkill plus take more board space than single resistor.
Sure, if that is how you manage BOMs and parts counts, by all means add more parts to use old stock
What is wrong with reusing the old stock for prototyping? We don't want to simply throw them out and make more e-waste.
