Hello
I joined this forum to get help designing a circuit to power my daughters trains with a 9v battery but reduce the current to around 1.5-5 volts. They normally run on 1.5 volts. The reasons why I want to do this is. 1. Because I can....
2. I think the battery will last longer. (I may be wrong here.) 3. I'd like to have a variable output to have either predetermined voltages, or using a pot so the engines have 3 or more speeds.
I have a YouTube channel.
You can see why I want to do this on there. My daughter, Lilyana, is totally into these engines. Having this feature would win me Daddy of the Year! (not that I don't have that title already.
I'm thinking about using this chip:
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=163044417&uq=635548853418180909&CSRT=14532559758389010054I don't think those little motors take more than 500 mA.
That's about where I am at the moment.
I know a bit about electronics. I've wired up simple 555 blinking light circuits. I can solder fairly well.
I'd like some input, thoughts on this project.
Thanks for reading and watching my poor quality off of the cuff video!
Dan
