Author Topic: Dummy making a dummy load box  (Read 6102 times)
Offline Tim88Topic starter
« on: December 12, 2018, 05:26:23 am »
Well, a dummy compared to most here anyways  :-DD. Found this neat design at Milletts site http://www.pmillett.com/dummyload.html. Got the heatsink drilled, tapped and resistors mounted. Quite a bit of work, more than I figgered but the worst is over. Got the resistors and heatsink from the links on Millett's site. The fancy box was a tad too salty for me so got a $10 one on the fleabay. Cut the top of the box out with my chop saw then dremmel the corners. Made a template on MS paint, taped it to the heatsink and punched the drill holes for reference. Used my drill press to sink the holes which I highly recommend using to get them true. I used some hardened #6 screws I had laying around which on retrospect, wish I got bigger ones but I am cheap  |O. Used a hand tap, didn't have an end cutting tap in that size so ground the tip down. Working with aluminum can be tricky, gotta use tap oil so the tap doesn't bind. I am just going to set it up for 4Ω/8Ω and just use a double throw switch instead of Millet's fancy switches. Hopefully get her finished in the next day or two. Can post what materials and template if anyone wants.
The following users thanked this post: oPossum
Offline t1d
Re: Dummy making a dummy load box
« Reply #1 on: December 12, 2018, 06:36:37 am »
Excellent work, in the true DIY sense. Keep posting.
Offline not1xor1
« Reply #2 on: December 12, 2018, 08:32:41 am »
this is dummier than yours   ;D
« Last Edit: December 12, 2018, 08:37:28 am by not1xor1 »
Offline 001
  • Country: aq
« Reply #3 on: December 12, 2018, 09:00:04 am »
how do You use it?
« Reply #4 on: December 12, 2018, 07:40:36 pm »
Gettin there...
Offline Electro Detective
« Reply #5 on: December 13, 2018, 12:21:24 am »
Cadet Dummy likes this post   :clap:
Now where did I put that unloved old project box with tangled up power resistors and thick wire...?   :-//
Offline Jwillis
« Reply #6 on: December 13, 2018, 06:27:23 am »
I'm to dumb for those fancy gadgets.This is mine.
If it doesn't work I can always club small rodents with it.
Offline lordvader88
« Reply #7 on: December 13, 2018, 07:19:46 am »
I soldered some 10W resistors to some perf.board. , it's a start.
I a few more metal can power resistors on the way, where the hell are they, I'm getting worried they were never sent.
Online ledtester
« Reply #8 on: December 13, 2018, 07:42:30 am »
Here's an analysis of all of the possible resistances you can get using a suite of 1, 2, 4 and 8 ohm resistors (at t = 7:50):
« Last Edit: December 13, 2018, 07:47:23 am by ledtester »
The following users thanked this post: 001
Offline not1xor1
« Reply #9 on: December 13, 2018, 09:08:39 am »
how do You use it?
Are you referring to my power resistor box?
You just move the plugs and get 1Ω to 99Ω.
Of course it is useful just for AC (low frequency - I use it to test transformers) as electronic loads offer much better performance for DC.
Offline 001
  • Country: aq
« Reply #10 on: December 13, 2018, 12:46:22 pm »
how do You use it?
Thanx
What experiments You do with transformers?
Offline unitedatoms
« Reply #11 on: December 13, 2018, 01:08:32 pm »
nice boxes. There is an aluminum profile by Makersled.com looking exactly like for this purpose.
Interested in all design related projects no matter how simple, or complicated, slow going or fast, failures or successes
Offline not1xor1
« Reply #12 on: December 14, 2018, 09:43:08 am »
I have lots of salvaged unspecified transformers and want to get a rough idea of their power rating, etc.
But the real reason is that I had a lot of 10W power wound resistors and wanted to use them for something potentially useful.  ;D
Offline vk6zgo
« Reply #13 on: December 14, 2018, 09:54:39 am »
I remember my old Boss making the point years ago, that it is a "Test" Load not a "Dummy" Load,  because it provides a real load for the DUT.
A "Dummy"Load would be a fancy looking empty box!
Transmitter manufacturers usually eschew the "Dummy" term, calling the load you test with, either a "Test Load" or an "Artificial Load".
« Last Edit: December 15, 2018, 05:37:32 am by vk6zgo »
« Reply #14 on: December 14, 2018, 07:46:35 pm »
Found a place by me that is gonna laser engrave my faceplate for me. Figgered might as well make it pretty. Found a free version of CAD software so I could make a template with everything laid out already to lower the cost. Quite the learning curve to that software. |O
Offline tkamiya
« Reply #15 on: January 25, 2019, 09:50:04 pm »
I just use regular incandescent lights.  Parallel a few and it can take quite a bit.
Only thing is, it's ohmic value changes depending on how much you put in it.  But if you want a dummy dummy load, it's cheap and parts are widely available.
Offline schmitt trigger
  • Country: mx
« Reply #16 on: January 25, 2019, 10:17:19 pm »
Nice looking faceplate! Love the voltage/current labels, too.
I wish I had half your skill.
The following users thanked this post: not1xor1
Offline Gyro
« Reply #17 on: January 25, 2019, 11:02:45 pm »
It's worth keeping an eye out for 'old school', (school sometime literally), linear slider lab rheostats.  They make excellent resistive loads. One in my collection is a Zenith 3R3 @10A - that's 300W at 30V. Not only will it take an awful lot of power (even more with a small fan blowing across it) but it makes a great workbench heater in the winter.
Avoid the Chinese round potentiometer style ones, they don't have enough surface area or full current wiper rating.
Edit: My set comprises 3R3 @ 10A, 16R @ 4A and 135R @ 1.4A. Enough to cover most eventualities.
« Last Edit: January 26, 2019, 11:07:52 am by Gyro »
Best Regards, Chris
Offline battmyrne216
« Reply #18 on: January 27, 2019, 05:12:59 am »
You have inspired me to make a big power resistor. I plan on also making a 4" 6.5 ohm I like how this turned out.
« Last Edit: January 27, 2019, 05:18:14 am by battmyrne216 »
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #19 on: January 27, 2019, 05:26:18 am »
I see you use the same power rating method I use.
The following users thanked this post: battmyrne216
Offline bdivi
  • Country: bg
Offline Doctorandus_P
« Reply #21 on: January 27, 2019, 01:11:07 pm »
Now this is a resistor:
https://www.aliexpress.com/item/Ceramic-2500W-Tube-Wirewound-Resistance-used-as-dump-load-resistors-braking-resistance/32831870690.html
In some of these tubular resistor there is a 3rd terminal in the middle with a screw and these can be adjusted...
Found an example on:
https://www.aliexpress.com/item/WaveTopSign-High-Power-Porcelain-Tube-Adjustable-Resistance-RX20-Ceramic-Resistor-Power-300-1500W-Resistance-Value-0/32966105005.html
And apparently these go upto 10kW, and they have a short time overload capability of 100x...
« Last Edit: January 27, 2019, 01:14:43 pm by Doctorandus_P »
Offline H713
« Reply #22 on: January 30, 2019, 05:35:25 am »
Not really so much of a box, but it works pretty well. It's spaced off the back wall of the bench by about 1/2 inches to allow air ventilation (also I was too lazy to mill out pockets for the nuts on the back). Those are 8 ohm "100W non-inductive" resistors from China. I haven't manage to blow them up yet. If I want a 4-ohm dummy load, I connect the second resistor in parallel with clip leads. If I don't need to test two channels at once, I can go up to 32 ohm or down to 2 ohm.
Nobody ever said a dummy load had to be smart. When I get around to re-doing my bench, I'm going to make a rackmount dummy load that will have more options, including 8 ohms at 1500W for load testing big amps, and some higher values for load testing transformers and power supplies. And It's going to have a fan so I never have to stop and wait for it to cool down like I do now.
Another type I've seen for lower values in physics labs is a big spring-like coil of nichrome wire submerged in a tube of water. Supposedly they can take a tremendous amount of wattage due to the high specific heat of water. Just be sure to top it off every now and then.
  • Country: mx
« Reply #23 on: January 30, 2019, 08:19:11 pm »
A "What if" type of question to the cognoscenti in this board:
If you were to do a binary-weighted resistor load (1, 2, 4, 8 ohms and so forth) to be wired in series to obtain discrete arbitrary values.... how would you allocate the resistor power rating for each?
I would assign the highest power rating to the lowest valued resistor.
Let's say you want a load with a maximum 20 volt input voltage. Then the 1 ohm device would be 400 watts, the 2 ohm 200 watts, 4 ohm would be 100 watt and so forth.
Would this be a sensible approach?
Offline SiliconWizard
« Reply #24 on: January 30, 2019, 09:46:45 pm »
That sounds about right.
If you have a chain of resistors in series, the same current will go through all of them. For each of the resistors Rk, the worst case will be when it's the only one that is used, thus Pmax = Umax^2 / Rk.
