Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Implementing an interchangeable RS232 pinout
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Implementing an interchangeable RS232 pinout (Read 1489 times)
michaelym
Regular Contributor
on:
December 16, 2012, 03:42:55 pm »
I need to figure out how to use two RS232 pinout variations with the same RJ45 connector and cable.
I tried Googling for an IC that will do the job but I don't know what keywords to look for.
The pinout can be set by the software and I don't need my circuit to detect it.
Any ideas?
Logged
david77
Frequent Contributor
Country:
Re: Implementing an interchangeable RS232 pinout
Reply #1 on:
December 16, 2012, 04:07:22 pm »
Maybe analog switches or multiplexers, CD4066 or 4051?
Logged
AndyC_772
Super Contributor
Country:
Professional design engineer
Reply #2 on:
December 16, 2012, 06:10:18 pm »
The easiest way may be to use two RS232 transceivers, each wired according to one of your required pinouts, and then to enable only one or the other. You'll need a transceiver which can have its output turned off and made high impedance.
Logged
CEL | Reliable Electronics
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
