Author Topic: Soldering DC charger to F-type connector cable  (Read 756 times)
Offline UnerTopic starter
« on: May 21, 2024, 05:42:59 am »
I want to solder a new charger like this:
2229133-0
So I think I need to buy 14V 1A+ AC/DC charger and solder it to F-type connector,
But I'm not sure where should I solder the GND to on the connector
And if I solder the DC charger to the wire itself which of the parts is the GND? (The Aluminum shield?)
Thanks.
« Last Edit: May 21, 2024, 05:47:21 am by Uner »
Online jpanhalt
Re: Soldering DC charger to F-type connector cable
« Reply #1 on: May 21, 2024, 05:52:49 am »
Aluminum is not easy to solder and the central connector may be copper plated steel.  You might be able to solder to a standard connector and the center conductor, then heat shrink over it.
Offline jonpaul
    • IEEE Spectrum
« Reply #2 on: May 21, 2024, 06:21:48 am »
find correct female F connector, wire to charger.
YOU CANT SOLDER TO THIS CABLE
Only crimp
j
The Internet Dinosaur..
passionate about analog electronics since 1950s
« Reply #3 on: May 21, 2024, 08:11:20 am »
Thanks for your reply,
jpanhalt, What do you mean by a "standard connector"?
jonpaul, How do I know which is the "correct" female f connector?
« Last Edit: May 21, 2024, 08:18:10 am by Uner »
Offline jonpaul
    • IEEE Spectrum
« Reply #4 on: May 21, 2024, 08:27:51 am »
F Jack Panel Mount F-61 Connector Solder Type Chassis
very common see local electronic disty or Amazon, ebay etc.
j
Online jpanhalt
« Reply #5 on: May 21, 2024, 10:14:26 am »
I meant  a connector plated  with a solderable metal, like nickel. I suspect that's common.  Then, solder a wire to the connector and crimp that to your Type F coax shield.
A female connector, as shown by jonpaul, could be soldered to the leads from your power supply.  Then use a gender changer  to get the male Type F .  They are about $6 at Amz.
