I'm an undergraduate biology student at Fairmont State University in Fairmont, WV. I'm planning on doing a undergraduate research project over the summer that will involve digitizing a honey bee hive. My adviser has been doing research with bees for years now and has just presented his data of weight measurements of a hive (collected weight every 5-10 minutes for two years) and it has raised some questions that we think additional data can answer or is needed.
My proposal is to build and implement a comprehensive sensor package as we can for our meager budget. Because specialized equipment for this runs into hundreds to thousands of dollars we're looking at building most of the equipment ourselves.
I'm looking to build a complete weather station with an arduino base. Wind speed/direction, rainfall, air temp, soil temp, humidity, barometric pressure, soil moisture, leaf wetness sensor, visible light reading, UV index. Each of these sensors presents different challenges but so far none have very complex circuits.
I'm also looking to build a bee counter based off this instructable:
http://www.instructables.com/id/Honey-Bee-Counter/?ALLSTEPSI'm also interested in collecting 3D temp profile of the hive for estimating brood size (Bees keep their brood at specific temp, but rest of hive isn't tightly temp controlled), idea based off this project:
http://mietz.imkerforum.de/the_idea.htmlThe basic plan is thus: 3 arduinos at the hive location. The hive has a roof shelter to protect the digital scale it sits on, along with mains power ran to it for the scale. A conduit was burried in the ground from the house that contains a RS-232 cable for the scale along with power. We plan on cutting the RS-232 wire off at the end, tying a rope to it and pulling it back through the conduit then feeding at least 2 cat5/cat6 cables back through, reconnecting the scale with a RS-232 to RJ45 adapter and getting it back working that way, then using the other cat5/6 cable to communicate with the arduinos with a master arduino back at the house. I'm thinking RS-485 as the protocol for that communication.
The master arduino will have a SD card and/or be connected to the computer that is logging the weight to save out a CSV file of all the sensor data at 5 or 10 minute intervals. It will also contain monitoring circuits, display (oled or whatever) to display information about the system, or alerts about anything wrong.
The arduinos at the hive site should be on a UPS battery backup so that they continue functioning for power failures. The mains supply is on a generator backup but it can take up to a minute to kick in, and worse case the battery should run the arduinos for at least a day. Small battery backup also is necessary for the arduino back at the house controlling the hive arduinos.
I'm a biology major not a EE major and my school doesn't have a EE degree so there isn't a plethora of people familiar with electronics here to help. SOO... I'm reaching out to people on the internet to help aid in the circuit design for this project.
I thought I'd stop in here to see if theres any willing people who want to help guide a noob through these circuits, check my designs, create circuits, whatever. ;-)
I plan on releasing all the code and circuits as open source and public domain, since I'm wanting others to help learn from this project and further the research on bees. Plus some of these circuits have wide applications beyond just my narrow research goals. ;-)
