Author Topic: Switched capacitor filters  (Read 861 times)
Offline schmitt triggerTopic starter
  • Country: mx
« on: October 20, 2020, 10:11:51 pm »
Just a curious question;
Is anyone here actually still using switched capacitor filters?
I remember when I first played around with the MF10, and felt it was the best thing since sliced bread.
National and many other started to offer a large portfolio of devices, but nowadays the offerings have been pared down.
Are they still viable building blocks?
Offline tggzzz
Re: Switched capacitor filters
« Reply #1 on: October 20, 2020, 10:20:29 pm »
The Tayloe mixer (as used in SDR dongles) is one form of switched capacitor filter.
Apart from that, the relentless improvement in ADC speed/resolution means that it is often easier to filter samples in the digital domain.
Online Alex Eisenhut
  • Place text here.
« Reply #2 on: October 20, 2020, 10:20:45 pm »
I would say their heyday is firmly in the past...
https://www.tinaja.com/glib/muse91.pdf
  • Country: mx
« Reply #3 on: October 21, 2020, 12:18:49 am »
That is my feeling, based on the reduced availability of types.
Regardless, I feel a little nostalgic about this nifty building block.
A similar fate occurred to the bucket-brigade devices. Nowadays audio delays and reverbs are implemented in DSP.
  • Place text here.
« Reply #4 on: October 21, 2020, 01:45:33 am »
I would be perplexed and nonplussed if I saw one in a modern design. For hobby stuff, have at it!
  • Country: mx
« Reply #5 on: October 21, 2020, 03:15:11 am »
Agree, OK for hobby use.
Because isn’t that what a hobby is all about? Indulging in obsolete technology for the sake of it?
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: October 21, 2020, 10:15:35 am »
Why would you want something discrete-time that you can't reprogram endlessly -- like a DSP? ;D
They're good for fixed filtering applications with monolithic integration I think, and the clock variable response is a neat trick -- but other than that, I don't think there's much point.  With DSP-capable MCUs being so common these days (yes, even the humble ATMEGA is capable of a small amount of DSP) I'd much rather plop in one of those.
Seven Transistor Labs, LLC
