Author Topic: Duty cycle device for a switching power supply?  (Read 1043 times)
Offline PlasmateurTopic starter
« on: April 17, 2019, 10:35:45 pm »
Hello. I'm wondering if such a device exists, and if it can be remotely controlled.
I would have a 48V 50A power supply, where I need to put some kind of duty cycle on the DC.
I'm guessing I could use some kind of fast remote switch, but I'm not sure if that switch would go on the AC side or DC side of the power supply.
Is something like this commonly used?
Offline pwlps
The following users thanked this post: Plasmateur
Offline jonroger
Re: Duty cycle device for a switching power supply?
« Reply #2 on: April 18, 2019, 03:57:49 pm »
But be sure to use only SSRs designed for DC output.
I am available for custom hardware/firmware development.
Offline james_s
« Reply #3 on: April 18, 2019, 11:27:29 pm »
How often do you need it to switch?
You could switch the output with a mosfet. If low side switching is adequate then a single N mosfet can do this really easily.
« Reply #4 on: April 20, 2019, 02:01:05 pm »
Thanks everyone! I'll check into the suggested devices. A solid state switching relay sounds great as I can probably just remotely control it with a function generator.
