Author Topic: Temperature Sensor - choice / reliabilty  (Read 10027 times)
Offline LukeW
Re: Temperature Sensor - choice / reliabilty
« Reply #25 on: July 07, 2015, 10:33:16 am »
One of the downsides of the DS18B20 is that it's pretty expensive, if you don't need the multi-drop 1-Wire bus and you're only working at approximately room temperature. A thermistor or bandgap sensor would be far cheaper.
Offline jdraughn
« Reply #26 on: July 07, 2015, 01:49:04 pm »
I really like the MAX31725, +/- .5ºC accuracy from -40ºC to 105ºC, and .00390625ºC resolution. It uses I2C. $1.48 each in quantities of one from DigiKey. http://www.digikey.com/product-detail/en/MAX31725MTA%2B/MAX31725MTA%2B-ND/3737668
Offline oilburner
« Reply #27 on: July 07, 2015, 10:19:49 pm »
cool chip, thanks jdraughn!
Offline nctnico
« Reply #28 on: July 08, 2015, 09:35:14 am »
For measuing temerature around the 25c mark, off board at about 2 mtrs and to a resolution of 0.1c ,  wondered what device the professional designers  would choose for long term reliabily, a NTC or digital sensor like the DS18B20 ?
I'd choose the NTC because digital communication and chips are prone to noise. I have had SPI temperature sensors fail due to too much noise on the board. The SPI communication ran fine it was just the chip itself which crapped out.
Offline jdraughn
« Reply #29 on: July 08, 2015, 12:22:30 pm »
Here are the breakout board files I made in Eagle for the MAX31725 if anyone wants them. it's 80 cents for 3 boards from OSHPark.com.
