Author Topic: DVI-D Shielded Backshell Kit  (Read 1034 times)
Offline bugroboticsTopic starter
« on: February 23, 2019, 05:24:48 pm »
I'm looking for DVI-D shielded backshell kits to build my own cable assemblies.  Shielding is hit and miss with the countless cables we have purchased (DVI-D to HDMI).  These cables are going into aircraft for a product so EMI needs to be kept to a minimum.  I've built up a few cables using D-Sub backshells (https://www.te.com/usa-en/product-1-2308341-6.html) and although they will fit the DVI-D connector and reduce the noise significantly the fit isn't perfect and I was hoping to find something designed for DVI with the correct screws and accommodating of the DVI connector sheet metal housing crimps.
Not finding anything specific other than the discontinued MicroCoss system from Molex (https://www.molex.com/mx_upload/family/microcross_dvi/056dvi.pdf).  Any help would be appreciated.  Thanks.
