Author Topic: Help identifying a crystal oscillator  (Read 2086 times)
Offline rob.mandersonTopic starter
« on: June 19, 2016, 05:26:21 pm »
Well, it's pretty well identified on the can - the problem is I can't find anything on line about it (like pinouts, working voltage etc).
I acquired 5 100 Mhz crystal oscillators - 14 pin dip form factor but only pins in the 1, 7, 8 and 14 positions.  The printing on the can is Cardinal LM 1400E 100 MHz.  Tried the obvious (pin 1 as o/c or en/dis able, pin 7 as ground, pin 8 as output and pin 14 as VCC - 3.3 volts initial guess).  Can't see any output but draws about 400 mA which seems very high.  Since the current drain seemed high I haven't tried 5 volts or higher.
I found the Cardinal website but could find nothing about LM 1400E on there.  Any ideas?
Rob
Offline dadler
Re: Help identifying a crystal oscillator
« Reply #1 on: June 19, 2016, 06:42:48 pm »
The following users thanked this post: rob.manderson
Offline uncle_bob
« Reply #2 on: June 19, 2016, 06:59:13 pm »
Hi
The data sheet cited above is a pretty good guess. The fact that you get 400 ma strongly suggests you have the supply hooked up backwards.
One comment on the data sheet:
The supply is either -5.2 to a supply pin, case to ground *or* +5.2 to supply pin, case to ground. The sheet sort of suggests that you hook it up with -5.2 to one pin and +5.2 to the other .... not a good idea.
If it is PECL (per the data sheet), you may not see anything on the outputs until you terminate them with a load resistor.
Bob
Online PA0PBZ
« Reply #3 on: June 19, 2016, 07:04:24 pm »
But... the E suggests that VCC is pin 14 and max current is 140mA @ 5V. I guess you can try to reverse the supply but I don't have a lot of hope it will work.
Offline uncle_bob
« Reply #4 on: June 19, 2016, 07:20:36 pm »
Hi
The E on the part may not correspond to the E pinout on the data sheet. The ECL pinouts listed are the next set to run through if the normal CMOS pinouts have not got the part working.
Bob
« Reply #5 on: June 19, 2016, 08:23:40 pm »
Thanks.  It turns out that it does indeed follow the E pinouts in that data sheet - buggered if I know why it was drawing 400 mA yesterday when it's drawng about 130 mA today.  But it was necessary to load the output as commented upon - for test purposes I've run two 510 ohm resistors in series from Vcc to ground and connected the output to the junction.  And there it is, a nice 100 MHz sine wave on the 'scope - which goes to show how deceptive the 'scope can be - lots of nice odd harmonics on the Spectrum Analyser - out to 1.1GHz.  I think my simple comb generator will be easy to finish now!  :)
Online PA0PBZ
« Reply #6 on: June 19, 2016, 08:26:01 pm »
Weird stuff happens  :) Good that you have it running now!
