Been doing some searching and so far not finding much on this topic...
Situation:
A sensor supply tracking regulator goes out of the product and could be subjected to wiring harness faults. The regulator IC can withstand I think it was 45-50V. The system could have 60V. So, the design had a 100V blocking diode to protect the regulator and a 25V MLCC was used as the filter cap since that diode would be there to protect it as well.
So, customer was complaining the sensor supply voltage is not precise enough (there is even a ADC on the micro to read it for ratiometric adj....) The load regulation with the diode in series is pretty poor I agree. So, a revision got rid of the diode and changed the agreed upon requirement spec so only a 40V short was allowed.
Now, I am circling back on documentation I see this 25V cap sitting there that got overlooked in the rush. Ugh.
The test lab actually did the 40V shorts test and nothing failed... The spec calls for a 1 min duration short.
What to do?
The proper solution is get a 50V cap but I cannot do a board layout rev now if I can't find one that fits the same space. So far, seems like I can get a 50V part of the same C and size if I go with a wider tolerance on the dielectric. The problem there is the minimum C value is below the regulator requirements. Actually, even the current part fails that in the corner conditions. Need to get with the application engineer for that regulator vendor for more details than the datasheet is telling me...
So, the bottom line question here at the bottom line... Are there any surge ratings common for MLCC caps? not mentioned in 2 of the 10 or so approved vendor datasheets for this part in my employers system.
