Author Topic: EAGLE: Exporting a BOM file and CPL file for JLCPCB SMT Assembly  (Read 6249 times)
Offline MrDTopic starter
« on: November 17, 2019, 01:36:58 am »
I've completed the design for my PCB for my Flash-based Mega Drive cartridge I mentioned in another thread. I'm now up to the stage where I need to send it to JLCPCB and get it evaluated and priced.
According to the JLCPCB SMT Assembly website, I need two files:
- BOM file(Bill of Materials) (.xlsx spreadsheet)
- CPL file(Component Placement List / Pick & Place File (PNP) file) (.xlsx spreadsheet)
Can somebody point me to instructions and/or an example on how to export these files from EAGLE in the correct format for JLCPCB's service?
Offline luiHS
Re: EAGLE: Exporting a BOM file and CPL file for JLCPCB SMT Assembly
« Reply #1 on: November 17, 2019, 05:51:29 am »
You can use the CAM of the Eagle. At least in version 9 there are options to generate the BOM and PnP files.
« Reply #2 on: November 19, 2019, 12:51:19 am »
Thank you.
In the CAM Processor I can export a CSV for the BOM, and I guess I have to manually swizzle it in Excel to get it to match JLCPCBs expected columns?
There's no option to export a PNP file though? This is in EAGLE 9.4.2.
Offline luiHS
« Reply #3 on: November 19, 2019, 03:48:09 am »
JLCPCB accepts files in CSV format.
And to generate the PnP files, you can use a ULP, for example mountsmd.ulp. I use the one that generates files for the Neoden4 because I have my own Pick and Place machine.
« Last Edit: November 19, 2019, 04:01:41 am by luiHS »
« Reply #4 on: November 19, 2019, 07:30:03 am »
I appreciate you walking me through this, I'll let you know how it goes.
Offline MagicSmoker
« Reply #5 on: November 19, 2019, 01:52:04 pm »
I still use v7.7.0 of EAGLE - not convinced joining the Borg is worthwhile - and to generate a BOM with that version I use the attached and zipped ULP. Run it while in the schematic and select the list type as values output as CSV and ; for the separator.
And why did I name the ULP 1-...? So it would be at the top of the selection (along with other handy ULPs like "zoom-unrouted").
« Reply #6 on: November 22, 2019, 05:52:07 am »
This is the output from JLCPCB's BOM/PNP uploader with my board. I think some manual finessing is in order here!
This is with the rotation values given by moundsmt.ulp
My IC footprints are mostly from https://eagle.componentsearchengine.com which I guess don't match up to the orientations of the pieces in JLCs database.
Should I edit my footprints to match JLC's expected device orientations, or just edit the rotation column of my PNP?
K1 and the two pinheaders aren't being assembled by JLC
« Last Edit: November 22, 2019, 07:24:33 am by MrD »
« Reply #7 on: January 10, 2020, 01:35:35 am »
In the end I went with PCBWAY, and sent them a very specific example image with the pin 1 locations clearly marked. Very pleased with the result.
Offline donotdespisethesnake
  • Embedded stuff
« Reply #8 on: January 10, 2020, 01:19:16 pm »
I suspect JLCPCB automation just doesn't work properly, and in fact they don't use it. A human operator goes through every placement to visually verify, which is why they flag issues if they can't see the pads clearly marked.
Bob
"All you said is just a bunch of opinions."
