Author Topic: Connector ID - PLC cable - AL-232cab  (Read 632 times)
Offline jdev99Topic starter
« on: April 25, 2024, 10:51:28 am »
I am looking for a connector to try to make a programming cable for a little  Mitsubishi Alpha2 PLC.
What is this connector called?
Thank you for any assistance.
Joe
Re: Connector ID - PLC cable - AL-232cab
« Reply #1 on: May 05, 2024, 10:48:56 am »
Anybody, any idea ??
Offline RitschRatsch
« Reply #2 on: May 05, 2024, 07:26:22 pm »
I can't think of anything right off the bat, but I always use GoogleLens or AliExpress Photo import for these kinds of questions. What we'd need now are some details, like pitch and contact size.
With kind regards
RitschRatsch
Offline HwAoRrDk
« Reply #3 on: May 06, 2024, 06:49:24 am »
Given that it's a Mitsubishi PLC, looking at Japanese-made connectors is likely to give results. JST, Hirose, etc. Maybe also Molex, as some of their stuff is designed in Japan.
Do some basic measurements - pin pitch, receptacle width/height, etc. Basically any attribute that will allow you to narrow down to certain product lines.
Offline coromonadalix
« Last Edit: May 06, 2024, 04:48:06 pm by coromonadalix »
