You have nowhere near sufficient clearance between that pour connected to Neutral and the mounting holes (2 - 3mm is usually about right depending on the degree of atmospheric contamination and the tracking index of the PCB material in use (Tracking index is somewhat variable depending on the quality of the PCB, ask board house for this information)).
Also the pot mounting bracket is connected to a live conductor (Phase and Neutral are both 'Live' conductors for the purposes of safety, and should be treated as such), you might want to earth this instead or use an all plastic pot.
Please tell me the Triac is an isolated tab model and that the heatsink is grounded.
There is, I take it a honking great inductor for RFI suppression somewhere in the system, or that thing will radiate from DC to daylight.
Regards, Dan.
