Hello! This is my first post here, and I just finished prototyping a audio amplifier on a breadboard. I plan on powering it with a power supply module I salvaged out of an old DVD player(I checked the power module's outputs with a meter). However on a previous audio amp, I had a problem with it not being grounded properly. I noticed that on most commercial power supplies, the ground planes are split internally, but are linked via a pair of optocouplers. Why is this? why not just bypass the optos and connect to a earth pin?
( with a simular but smaller power module, it used a chasis ground to the metal case. when connected to power and earthed to the outlet, there was a sudden and violent release of magic smoke
) Why is this?
