Author Topic: Easiest way to add WPA2 Entreprise support ??  (Read 575 times)
Offline jemangedeslolosTopic starter
« on: May 01, 2020, 03:39:55 pm »
Hello,
I have a custom board with sensors that transmit datas to online IoT plateform (Thingspeak )  with onboard wifi ( ESP8266 + AT commands ).
All is working great...except that now I need to connect my board to a Wifi that only accepts WPA2 enterprise authentication.
Does anyone have experience using wifi module who supports WPA2 Entreprise authentification ? ( ESP8266 if possible  >:D )
In the ESP8266 AT Instruction Set PDF, it is clearly indicated that AT can NOT connect to WPA2 Enterprise AP.
Thank you for your help :)
Offline nuclearcat
  • Country: lb
Re: Easiest way to add WPA2 Entreprise support ??
« Reply #1 on: May 06, 2020, 09:54:14 am »
ESP8266 RTOS SDK does support WPA2 enterprise, but i guess you need to write firmware to have necessary functionality, or hire someone.
Here is example:
https://github.com/espressif/ESP8266_RTOS_SDK/blob/8456b7450e06c67d434323c5b41185f878c8945f/examples/wifi/wpa2_enterprise/main/wpa2_enterprise_main.c
