Setting # of satellites to use:
It appears from looking at the protocol spec that you can limit the number of satellites (a.k.a. "SV" = Space Vehicles) using the NAVX5 setting;
From page 196 of the u-blox6_ReceiverDescrProtSpec document:
"The minimun number of SV default setting is set to 1 in a firmware with the timing premium feature enabled (LEA-6T)"
which totally figures, the default minimum for non-timing GPS modules is 3.
There's also "Maximum number of SV" = 16, the GUI will let you set this as low as 2.
Furthermore on the "NAV5" setting there is "Min SV elevation" (default 5 deg) described as "Minimum elevation of a satellite above the horizon in order to be used in the navigation solution. Low elevation satellites may provide degraded accuracy, due to the long signal path through the atmosphere."
Not tested either but that looks promising if you want to limit angles/and #SV's.
I like "SV", it sounds kinda techy and also suitably open-ended for future enhancements, i.e. if in future instead of satellites we launch, say, Donald Trump into a 12,550 mile high orbit.
