Author Topic: Edge launch or horizontal male BNC jacks?  (Read 1385 times)
Offline TERRA OperativeTopic starter
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« on: March 19, 2020, 01:38:28 pm »
I'm looking to build some attenuators and such and I'm having trouble finding edge launch or horizontal PCB mount male BNC jacks.
Can anyone point me in the direction to find a handful of these in 50 Ohm rating? Digikey and Mouser have a wide selection of female but basically no male..
Online thm_w
  • Non-expert
Re: Edge launch or horizontal male BNC jacks?
« Reply #1 on: March 19, 2020, 10:11:32 pm »
Yes male right angle BNC is quite hard to find. I saw a few sources but nothing easy to buy, so I wrote them off for hobby use.
If you need a lot then I'm sure you can get it from one of these suppliers:
https://www.alibaba.com/product-detail/BNC-male-right-angle-for-PCB_60721985419.html
https://www.elecbee.com/en/bnc-connector/1758-475-bnc-pcb-mount-right-angle-male-connector-through-hole.html
One option is to use SMA (edge or R/A) then a SMA to BNC adapter, as the adapters are commonly available. Another can be use panel mount + pigtail, or vertical bnc via a right angle adapter board.
You can do a dual BNC/SMA right angle footprint, to populate with either connector type.
« Last Edit: March 19, 2020, 10:13:07 pm by thm_w »
Offline enut11
  • Love building/modifying/restoring test equipment
« Reply #2 on: March 20, 2020, 12:27:04 am »
They are available on eBay for around $2 each
an electronics nut from wayback...
  • Country: jp
« Reply #3 on: March 20, 2020, 02:17:02 am »
Yeah, I found those ones you linked, I just need a few, not 100 of them though.
This one would be perfect if I could buy like 10 or so:
https://www.alibaba.com/product-detail/RF-50ohms-ST-180-degree-edge_60634004992.html
Anyone in for a group buy? :D
I'm thinking of getting a vertical one to see if I can mount it horizontally by wedging the PCB between the legs. That might work ok.
Do you have a link? I can only find vertical type.
Online thm_w
  • Non-expert
« Reply #4 on: March 23, 2020, 01:28:23 am »
I asked that seller and sample price is $1/pc + $30 shipping, 20pc max, bit too much for me.
Would work if you just mounted it on one side of the PCB, with 3 SMD pads top and 2 SMD pads bottom. Use solder fillets on the bottom two pads to connect to the main body of the connector. Pads would have to be close to the edge of the board.
The wedging idea would add a bit more strength but it might then not butt up flat against the PCB.
  • Country: jp
« Reply #5 on: March 23, 2020, 02:00:28 am »
Yeah, I think I might give that a go. I think if I give it decent sized pads to get a good fillet, it should be strong enough.
Those prices you found are a bit pricey for me too. :D
Offline Whales
    • Halestrom
« Reply #6 on: March 23, 2020, 04:46:29 am »
Complex idea: Two PCBs in parallel.  Mount standard chassis-style BNC into a big hole on one board (perpendicular to the PCB, as if it were a chassis).  Solder the center pin into a small hole on the other board.
Interconnect between boards might not be nice, but you also might be able to get away without making a case if you put some small feet or a 3rd dummy PCB as an insulator on the bottom board.
« Last Edit: March 23, 2020, 04:50:24 am by Whales »
Offline ogden
  • Country: lv
« Reply #7 on: March 23, 2020, 04:51:32 am »
Check this thread about BNC attenuators - maybe you will get some idea (hint: SMA).
« Reply #8 on: March 23, 2020, 05:54:45 am »
Yep SMA is the cost effective and practical solution:
https://www.aliexpress.com/item/32912568609.html?spm=a2g0s.9042311.0.0.56164c4dvpBF7x
