Author Topic: EEZ Bench Box 3 (BB3) and beyond...  (Read 202283 times)
Offline prasimixTopic starter
  • Country: hr
    • EEZ
Re: EEZ Bench Box 3 (BB3) and beyond...
« Reply #700 on: March 11, 2025, 10:23:32 am »
I just tested the ULN2803A I have, and it starts working from 1.6V. Maybe too close to 1.8V to be considered safe to operate.
  • Country: hr
    • EEZ
« Reply #701 on: March 15, 2025, 06:47:39 pm »
In DIB 2.0 I added Quad SPI (QSPI) as one of the communication channels. Unlike standard SPI where there is MOSI and MISO (both unidirectional) here there are 4 lines that are bidirectional. The question arises how to isolate it? Does anyone know of a 4-bit bidirectional digital isolator?
  • Country: hr
    • EEZ
« Reply #702 on: March 15, 2025, 07:00:01 pm »
To make things more complicated, the rail voltage on one side should go down to 1.8V. So unfortunately, for example, Onsemi NCID9401 is not a viable candidate.
Offline Kean
    • Kean Electronics
« Reply #703 on: March 15, 2025, 07:14:39 pm »
Maybe the Silicon Labs/Skyworks Si86SQ44BE which seems to be designed specially for QSPI as it support direction input from one side (output at other) as well as output enable control from both sides.
https://www.skyworksinc.com/-/media/SkyWorks/SL/documents/public/data-sheets/si86s6xx-datasheet.pdf
Listed at LCSC, but not currently in stock.  And Digikey/Mouser don't currently stock it either.  You'd probably have to go direct to Skyworks.
An eval board is available that you could maybe borrow chips from https://www.skyworksinc.com/en/Products/Isolation/Evaluation-Kits/digital-isolator/Si86SSxx-KIT
Alternative is to use a pair of TI 4-bit uni-directional isolators (e.g. ISO6740 or faster ISO7740) plus one extra single channel for isolation of the direction signal for output enables.  A little more expensive, and uses more board space, but the parts are readily available.
I've not used either of these, it is just something I have researched.  The QSPI host controller will need to generate the direction signal.
Further, for 1.8V rail support the TI parts should work, but the Skyworks would need a separate level shifter...
The following users thanked this post: prasimix
  • Country: hr
    • EEZ
« Reply #704 on: March 15, 2025, 10:24:15 pm »
Thanks Kean, I can find SI86SQ44 on Mouser and Digikey, price is similar to Onsemi, and yes, also will requires additional level shifter on 1.8V side. It has a slight advantage in terms of speed, going up to 150 Mbps.
  • Country: hr
    • EEZ
« Reply #705 on: March 16, 2025, 10:30:16 am »
Example of module isolation if it would use QSPI to communicate with the Master MCU. There is still the question of the QSPI CLK which if it is also bidirectional then another 1-bit bidirectional isolator will need to be added:
Offline Kean
    • Kean Electronics
« Reply #706 on: March 16, 2025, 01:19:55 pm »
As far as I know, the clock will always be unidirectional.
Won't you need to pass the chip select signal through the isolators as well?  Or did I miss something?
  • Country: hr
    • EEZ
« Reply #707 on: March 16, 2025, 05:46:10 pm »
Chip select is CSA and it's unique for each module. So, I'd like to use it to enable/disable QSPI isolator.
Offline Crazoff
  • Country: ru
« Reply #708 on: April 02, 2025, 08:15:27 am »
Hello. Can you tell me what output pulsations does BB3 provide at the output of the DCP-405 and DCM220 modules?
  • Country: hr
    • EEZ
« Reply #709 on: April 02, 2025, 08:19:54 am »
DCP405 supports programming lists and function generator where you can generate e.g. sine wave up to 200 Hz. All that you can check in online simulator: https://www.envox.eu/web-simulator/
Offline Crazoff
  • Country: ru
« Reply #710 on: April 02, 2025, 08:40:30 am »
I meant the noise at the output
  • Country: hr
    • EEZ
« Reply #711 on: April 02, 2025, 09:26:51 am »
Check under Measurements tab: https://www.envox.eu/dc-power-modules/dcp405-power-module/ (although it was done with entry level Rigol DSO)
Offline Crazoff
  • Country: ru
« Reply #712 on: April 15, 2025, 04:37:40 pm »
Hello. I'm starting BB3 little by little. So far, I have mounted only the DCM220. Everything worked without any problems. initialized, calibrated. Tell me, does the HID USB mouse not work? The USB keyboard is working fine. MCU r3B4 + bb3-v1.7.hex
Offline Crazoff
  • Country: ru
« Reply #713 on: April 15, 2025, 04:41:03 pm »
There is a connection with the computer, he also sees the memory card.
Offline Dirk Ruigrok
« Reply #714 on: May 09, 2025, 10:14:40 am »
Hello everyone,
I’m currently working with an EEZ BB3 (MCU r3B3) running firmware v1.7.6. I’ve been able to flash the firmware successfully using ST-Link, but the system doesn’t start correctly due to missing SD card content.
Specifically, I’m looking for the full SD card folder structure (especially the “bb3” folder with Lua scripts, config.json, startup.lua, etc.). Unfortunately, it’s not included in the GitHub release.
If anyone can share the SD image (e.g. bb3-sdcard-v1.7.6.zip) or point me to where I can find it, I’d be extremely grateful!
Thanks in advance,
Dirk
  • Country: hr
    • EEZ
« Reply #715 on: May 09, 2025, 05:04:26 pm »
Hi Dirk, please note that BB3 will start even with empty and properly formatted SD card. I don't understand what do you mean by config.json and startup.lua since that files are not present on the SD card.
