Hello,
I have a project I'm trying to work on, but ran into a snag.
I need something that is kind of like a two way mirror, but in black and not reflective.
Basically, I have a panel of plastic. It is silk-screened black with reversed words/graphics. I need the words/graphics to be only noticeable when a LED is turned on from behind them.
Exactly like how your check engine light or oil light comes on in your vehicle. How do they do that? You can't see them, until the LED or bulb is turned on behind them. Would, perhaps, window tinting film work for that?
It needs to be no more then 1/16 inch thick or 1.5mm thick.
Thanks in advance.
