Author Topic: Infrared emitter and detector component  (Read 971 times)
Offline rcourtneyTopic starter
« on: August 20, 2018, 03:09:43 pm »
Trying to locate a source for infrared emitter/detector functions both in same device.  Ideal device could have the detector in the center of emitters (6 perhaps)?
May try SMD detector in center of 6 SMD LEDs.
Possible detector: AMS.com  TSL25721 using channel 1
« Last Edit: August 20, 2018, 06:23:56 pm by rcourtney »
Offline floobydust
Re: Infrared emitter and detector component
« Reply #1 on: August 20, 2018, 08:48:20 pm »
Are you sensing position or distance?
There are IR linear distance sensors, and slotted/reflective optical sensors which have both emitter and detector in one package. Usually an LED and phototransistor.
Making one is not fun, a lot of work. Ambient light as DC from the sun, AC from incandescent lamps and HF AC from CCFL/LED lights is always present.
Sharp distance sensors
« Reply #2 on: August 23, 2018, 06:18:00 pm »
Amplitude of reflected IR light from image through controlled optics.
