Author Topic: Copper to Board-Edge clearance for DFM  (Read 2050 times)
Offline eecookTopic starter
  • Country: ar
« on: November 04, 2014, 03:20:55 pm »
Hi all,
I am working on a design where DFM is a concern. In particular I need to know what IPC has to say regarding copper to board edge clearance. Going through IPC-2222 I get to section "10.1.1 Edge clearance" but it only talks about copper to copper clearance as a function of voltage. I also went through IPC-7351 but is only for components and doesn't mention copper in particular.
I have worked with several manufacturers in the past and I know that in terms of manufacturing capabilities virtually anyone can deal with a 1mm clearance. But that's not good enough for my project manager who wants an "authoritative opinion" on the matter. I have wasted the whole morning googling and... nothing.
Does anybody know about any document out there that covers this subject, or at least something to shut him up? :)
Cheers!
Nullius in verba
Offline free_electron
    • SiliconValleyGarage
Re: Copper to Board-Edge clearance for DFM
« Reply #1 on: November 04, 2014, 03:48:19 pm »
0.5mm pullback is typical to avoid routing shorts. if you want to seal the internal structure : 2 mm will do it. this allows the prepregs to fuse properly without risk of peeling later.
Offline IconicPCB
« Reply #2 on: November 04, 2014, 08:37:27 pm »
Talk to Your board shop... after all they are the ones who will have to make it.
