So I have a project that involves wires being brought into an enclosure. Specifically, wires from limit switches, possibly 12V power from wires (or a barrel jack, but I have that connector situation handled as it's obviously super basic) and wires going out to a garage door opener circuit. I currently have the circuit set up so I have a 2 pin connector, a 4 pin and a 6 pin.
My original goal was to use plug-and-socket style terminal blocks (see attachment) and I feel like these would be the best option. However, they're not super cheap from what I've seen. The plugs cost $1.50-$2 from DigiKey each in low quantities, and the terminal blocks are about $0.60 each (which is reasonable, the plugs are the worrying part for me in terms of cost)
Are there any suppliers that it would be better to get these from? I've even looked on eBay and it's hard to find these in decent quantity in the pin numbers I want for really cheap.
My other option is to consolidate the terminal blocks into a 2 pin and a 10 pin, which would make the unique part count lower, saving a little (I hope) in cost.
Or, are there any better/cheaper options for what I want? None of these have to handle significant current, so that's not an issue. Maybe some kind of crimp-connector system would be better?
