Author Topic: Electret Microphone  (Read 2986 times)
Offline cosmarchyTopic starter
Electret Microphone
« on: March 11, 2020, 08:40:54 pm »
Hello all,
I have a couple of circuits which require 3-pin electret microphones:
947722-0
The trouble is that I cannot find any 3-pin varieties here in the uk.
Does anyone know of a reliable source for these?  What is the difference (apart from the obvious ::)) between the 2 and 3 pin versions?
Offline bob91343
Re: Electret Microphone
« Reply #1 on: March 11, 2020, 09:10:24 pm »
I think there is a discrepancy.  An electret provides bias without a power supply.  The circuits shown have a power supply, so they are probably not electret microphones, just ordinary condenser microphones that require power.  Well, to be precise, not power but polarizing voltage.
Offline floobydust
« Reply #2 on: March 11, 2020, 11:03:40 pm »
Modern electret condenser mics are all two-wire, ground and signal. You could use one in your circuit, just short the tip+ring connection together. They have combined power and signal to save a wire.
I think R1 is too low for a 9V feed, it is typically 10k-22k. The JFET in the mic is typically a 2SK596S with IDSS average 0.16mA if anyone wants to do math.
You might need an extra RC filter for the mic power feed, any audio ripple on the 9V rail can get into the mic circuit and cause oscillations/feedback. Worse with battery power.
edit: standard operating voltage is 2-3V for these mics, and you'd have to check the IDSS spec of the mic to get the best resistor value. It is not critical but the Internet is full of copycat errors.
TI Electret Microphone Pre-Amplifier Reference Design uses 2V for 13.7k at 9V
CUI mics specs 3V at 0.5mA max.
« Last Edit: March 11, 2020, 11:15:45 pm by floobydust »
Online NiHaoMike
    • Facebook Page
« Reply #3 on: March 11, 2020, 11:33:50 pm »
A 3 wire microphone allows adjustment of sensitivity.
https://sound-au.com/project93.htm
« Reply #4 on: March 12, 2020, 08:16:15 pm »
Thanks very much for your help guys, verymuch appreciated  :D
Offline Buriedcode
« Reply #5 on: March 13, 2020, 04:18:45 pm »
You can usually (but no always!) convert a 2 pin electret to 3 pin with a slight modification - called the "Linkwitz mod" but I'm sure others have done it before. NiHaoMikes link provides all the details.
I've found the 3 pin ones to have lower sensitivity, but also more linear.  As for noise, theres a great deal of variation, as there are so many cheap electret capsules, even some of the cheapest can be remarkably good.
Offline ploegmma
« Reply #6 on: June 05, 2020, 07:49:38 pm »
Maybe just use a two pin electret? If you're looking for a circuit, perhaps something like this:
https://hackaday.io/project/171404-microphone-the-dumbbellmic
