Train AC units, so probably not a good place for a scroll or other hermetic unit, the vibration will kill them pretty fast. You might want to look into semi hermetic compressors that are piston based, with a 3 phase motor as drive, and then a standard inverter block driver for them. At least with that you can use a 3 phase input converter, meaning you need around a 400VDC power supply to drive it.
