I contacted the Australian distributor and was quoted around $450 for the fixture. If it was a business with lots of people using it, sure I’d have no problems paying it. But for me, I can’t justify it when I know what the box contains (and it sure isn’t a lot of expensive stuff)
Since this post I have made up a few leads
My higher current dc lead uses Anderson connectors with banana Jax’s soldered on. The negative connects through, the positive has a break in it for current measurements and there are positive and negative at one end for voltage (nothing flash but did the job)
For AC measurement
I made a box, used it successfully and happily, then found tweaks that I would like to make, messed them up rendering the box useless. I then changed jobs and am only just getting the workshop set back up. All the equipment was mine, so it followed me when I left my job. The new job supplies all the equipment so now I have a awesome setup at home.
The things I found
I really wanted a way to turn the load on / off without unplugging anything. This makes it so much easier to do inrush measurements. I landed tonuse a DPST switch on the output of the box so the LMG can still pick up voltages without there being an output to the load.
Fuse on input (self explanatory), I don’t like to rely on fuses and I normally run unknown devices through the 1200va ac source before connecting to the mains just to make sure there’s no surprises waiting for me.
Inlets and outlets. I was working on items with IEC inlets, so having a flying lead out of the test fixture straight to a IEC plug worked really wel. I then had a IEC inlet on the side of the test fixture. I planned to make one up with normal 3 pin plugs and sockets too.
Labeling - make sure you label the box. I use JAC poly laser sheets a fair bit, durable and last a long time, so I had printed a label for the front of the box with lines of the connections. I didn’t want to look at this random box in a years time and forget what went where. Just a line schematic did the trick.
I’d completely forgotten about his thread, but when I get off my backside and make the test fixtures again with all the changes, I’ll update here.
As for the LMG, fantastic bit of gear. I was getting really frustrated with the scope view of the voltage and current waveforms taking ages to update. The digit displays would update fine, but it was just the waveform view that didn’t. Turned out the view window had been moved 15 seconds to the right, so the display was taking 15 seconds to update. Once I realized thisand moved the window back to where it should be, problem solved.
