Author Topic: First PCB design - advice needed  (Read 2577 times)
Offline RennenedeBananeTopic starter
« on: December 14, 2017, 11:04:00 pm »
Hey there,
I just finished my first PCB design, so be indulgently with me :)
I'd like to know what's there that can be improved. I'm sure I made a ton of beginner's errors.
Thank you.
Offline hermit
Re: First PCB design - advice needed
« Reply #1 on: December 15, 2017, 05:01:23 pm »
First beginners error is not posting the schematic and telling us what you want to accomplish with it. ;)
Offline wraper
  • Country: lv
« Reply #2 on: December 15, 2017, 05:14:52 pm »
You use extremely small pads for some large components. And it seems C10 and C11 would be impossible to mount with such hole size and distance if silkscreen represents actual cap diameter.
Offline ocset
« Reply #3 on: December 16, 2017, 03:43:34 pm »
Here is a  document on laying out pcbs with smps on them
Also, the time old favorite by the author of this website, Dave Jones himself
http://www.alternatezone.com/electronics/files/PCBDesignTutorialRevA.pdf
The following users thanked this post: ratio
Offline knapik
« Reply #4 on: December 17, 2017, 10:01:37 am »
I believe your green highlighted components means that they're colliding with another component. Have you run a design rule check?
« Reply #5 on: December 26, 2017, 03:10:04 pm »
Hello,
sorry that I left you without any reply, but Christmas was coming and what's the point of contemplative christmas time without any stress?
Yes, my bad. I attached screenshots of the block diagram and each schematic. I hope, that's helpful. The purpose is a universal soldering station, e.g. a station which can control several soldering irons from different manufacturers.
I got the pad size for each copmonent from the data sheets. So if I made no error with centimeter and inches, it should work. Or do they seem that small?
The silkscreen of C10 and C11 should represent the actual size. So why does it seem impossible to mount them? I have not that much of actual soldering experience, so I' honestly not sure why it shouldn't work.
Thank you, I will read it.
Yes, there are components where Altium thinks they collide. For example the display, which goes over the entire PCB, but will be mounted on spacers. The problem is currently that I cannot set the rules matching the PCB mill, because my university couldn't say which mill I can use for making the PCB. But if I made no error while creating the components, there should be enough room for each component.
Offline TomS_
« Reply #6 on: December 27, 2017, 12:13:52 am »
In my experience, which isnt necessarily industry experience, a capacitor that big would tend to have a bigger pitch. Perhaps if you can supply the manufacturer and part number someone will cross check. But Ive never tried to design something with so much capacitance, so you might take my words with a grain of sand.  ^-^
Offline wraper
  • Country: lv
« Reply #7 on: December 27, 2017, 12:31:35 am »
LOL what, 1N4148?  :scared:
Offline wraper
  • Country: lv
« Reply #8 on: December 27, 2017, 12:38:58 am »
How this is supposed to work? PCB layout is the least of your problems.
« Last Edit: December 27, 2017, 12:40:52 am by wraper »
« Reply #9 on: January 10, 2018, 10:38:02 pm »
Hey guys, thanks for your help so far. I had a talk with my supervising professor and it seems like I have to redo the PCB. But anyway, first to the things you mentioned:
data.tinkertubes.de/TDK_Alu_Elko_Snap_In_B41252.pdf This is the data sheet for the capacitors C10 and C11.
It seems a bit unclear if this size of capacitors has three pins (Quote from the datasheet: "Snap-in capacitors are also available with 3 terminals", so I thought they are available with two and three pins. Also the supplier had a picture showing two pins http://fi.farnell.com/epcos/b41252b7109m000/cap-alu-elec-10000uf-35v-snap/dp/2750101). If you want to take the time, I'd be glad to hear your opinion.
Ok, I get your point. Thanks for pointing out, I don't want to release the magic smoke. I recalculated the current in the rectifier and chose this diode instead: http://fi.farnell.com/on-semiconductor/sb5100/diode-schottky-5a-100v-do-201/dp/1467531. It's a Schottky, because it was the cheapest I found which fitted the requirements.
I hope I didn't make a complete fool out of myself. The complete topic of hardware design is new to me and I heard of transistors only in theory. But I think I found out why it wouldn't work. I attached a new version which hopefully does work.
To make sure I understood it: The problem was that the microcontroler couldn't provide enough voltage in order to make the transistor conduct. With the new setting, the 24V drops at the heating element and the transistor can conduct, since the base voltage can now be higher than the emitter voltage.
