Author Topic: Question about switching Rectified inductor with SSR.  (Read 278 times)
Offline StutterMeThisTopic starter
« on: November 14, 2024, 04:11:35 pm »
Hi All,
I've been trying to use a solid state relay to switch a contactor, and have been getting very unreliable results. I was curious if I could get some help and insights.
In particular the SSR's love to stay latched onto the on state of the device. Regardless of the snubber used.
Looking up online a little bit, this seems to be mostly because of the current wave form of the device, (and the corresponding dIcom/dt). I've attached an image below, of how the current wave form essentially looks like. I believe the contactor has an inbuilt rectifier, this causes a very high dI/dt , which keeps the SSR on. However from my understanding this mostly just affects triacs, and not so much SCR's. Here is a link to the SSR I'm using, and they say they are using SCR's so i'm wondering if the high dI/dt will also cause the SCR's to latch on. (https://www.mouser.com/datasheet/2/240/media-3321277.pdf and the contactor is https://www.se.com/us/en/product/LC1D115G7/iec-contactor-tesys-deca-nonreversing-115a-75hp-at-480vac-up-to-100ka-sccr-3-phase-3-no-120vac-50-60hz-coil-open/). For context the contactor has a draw of around 20-30 mA when on.
I've read some application notes about this, but for the most part they've been pretty light on the details (https://edata.omron.com.au/eData/Relays/Y108-E1-1.pdf and http://class.ece.iastate.edu/ee330/miscHandouts/AN_GOLDEN_RULES.pdf). I was curious if there were any other books / resources that go into a bit more detail, or describe a bit more in depth what the problem is here. Also are there any rule of thumbs for what dIcom/Dt is the max acceptable. Would also love to dive into the math of how this stuff works, normally helps me better understand how to design the stuff.
Am I correct in my assessment that it is a dI/dt issue or is there something else at play?
Thanks all.
« Last Edit: November 14, 2024, 08:08:29 pm by StutterMeThis »
Online Zero999
  • 0999
Re: Question about switching Rectified inductor with SSR.
« Reply #1 on: November 14, 2024, 07:18:53 pm »
Could it be back-EMF related? Try adding a MOV in parallel with the contactor's coil.
« Reply #2 on: November 14, 2024, 07:38:43 pm »
A move is an interesting idea. I don't have any right now so would have to buy them. I did have a similar idea, so I tried adding a RC snubber both directly across the relay and the contacts of the SSR, with little effect. One of the things is that this contractor does have a diode current shunt built in which does seem quite effective. The measured voltage rise rate was only about 50V/us (though tbh it was a bit hard to measure so I could imagine I could have affected it that way).
I had a hunch that it was maybe the dI/dt due to the rectified nature of the current which gives a really fast change (definitely way above 5 amps / ms)
Offline PCB.Wiz
« Reply #3 on: November 14, 2024, 10:16:37 pm »
So you are saying, once turned on, the contactor does not release ?  Does that happen 100% of the time ?
Do you have a scope to check the contactor coil waveform ?
The off state current may be enough to hold-in the contactor, the specs suggest the hold-in current is much lower than the peak pull-in current.
SCR SSR's need some current flow, to trigger the gates, so they never go to zero.
A power resistor across the contactor coil, would lower the voltage that sees in the off state.
It may be dV/dT more than dI/dT  - inductor loads are not that nice, the SSR releases when current crosses zero, which is when mains is close to max, so there are high dV/dT effects.
