Author Topic: Electrical noise-free LED workbench lighting  (Read 62648 times)
Offline 5U4GBTopic starter
« on: January 04, 2024, 02:49:58 am »
This came up indirectly in another thread, and there's been plenty of discussions of LED noise getting injected into measurements in other threads, does anyone have any thoughts on using a well-filtered linear supply for their LED lighting?  I was thinking of something like this (there are plenty of similar clones) which, if you're actually getting what the photos show, seems like a fairly solidly-designed low-noise DC source for powering an LED strip.  The one notable issue I can see on that one is the missing earth wire to the case, I'm assuming the metal plug body provides the necessary connection.
The following users thanked this post: BrokenYugo
Offline jonpaul
    • IEEE Spectrum
Re: Electrical noise-free LED workbench lighting
« Reply #1 on: January 04, 2024, 03:45:30 am »
Use high quality EU approved drivers, comply with EMI cond/radiated, CISPR, CE etc.
We specify TCI, Italy, no EMI issues, pure filtered DC out, variable current.
Avoid the low cost Chinese junk
J
The Internet Dinosaur..
passionate about analog electronics since 1950s
« Reply #2 on: January 04, 2024, 09:33:14 am »
I'm driving a $10 LED strip that lights the workbench from it, I realise I'm not getting anything CE (or whatever) certified or similar, but all I need is something that's good enough, i.e. can drive the LEDs without radiating a mess of switching hash into the surrounding area.
Offline Gyro
« Reply #3 on: January 04, 2024, 10:58:28 am »
If noise is a real issue for you then you could always build yourself a linear power supply to drive the strip, either with a 3 terminal regulator or a simple resistor after the transformer, bridge rectifier and reservoir cap. An added bonus would be total absence of flicker (if you are sensitive).
Best Regards, Chris
Offline Edison
  • Country: cz
« Reply #4 on: January 16, 2024, 12:30:57 am »
I made my work table lighting from industrial 24V led strips 2700Lm/m, I used a Mean Well industrial switching power supply for power supply and I couldn't stop being surprised. The light is absolutely flicker-free, but the interference was so intense that the BT mouse stopped working - when the transponder was brought closer, the mouse functionality problem disappeared, but the interference remained. The led strips were mounted in massive aluminum profiles and temporarily connected with an ordinary double line, I made a modification and replaced the double line with a shielded cable - the interference decreased by half and the problem with the mouse disappeared completely, then I added ferrite filters (also on the supply cable) and the interference is negligible - it will only show up with very weak radio stations of the test receiver.
the front light has 1.5m of strip in it and the rear 1m
« Last Edit: January 16, 2024, 12:33:05 am by Edison »
Everything works as the weakest link in the chain
The following users thanked this post: coromonadalix, 5U4GB
Offline CosteC
« Reply #5 on: January 17, 2024, 02:20:29 pm »
LED strip consisting only LEDs and resistors does not produce noise, yet it can radiate it. Elimination of this radiation is very expensive. It is much easier not to "pump noise" into LED strips.
I think, as mentioned earlier, that use of certified, high quality power supplies is key point. Chinese "low noise PSU" will not do it. In PSU linked in first post everybody can see how input and output wires from transformer are tied together to ALLOW noise coupling... It is not good design, despite lot of inductors and capacitors visible everywhere.
Another key factor is wiring. Good, tight wiring will just emit less noise. Large loops, separating "+12V" wire from "GND" wire create such loops acting as antennas.
Next cheap and efficient method is grounding. GND of PSU can be connected to PE (Protective Earth). It however opens large discussions about efficiency of such solution. There is however no definite answer as it is PSU dependent and location dependent. It is easy to make however.
Last interesting point is additional filtering. But is it needed if good MeanWell PSU will have 100 kHz 200 mV ripple at output?
Side note:
Most of cheap Chinese PSUs "for LEDs" does not have PFC, despite it is required for "lighting applications". This is yet another way to limit cost of PSU at expense of quality. Among of many other methods, where filter removal is probably first what comes to mind of owner of company competing on this market.
Offline coromonadalix
« Reply #6 on: January 17, 2024, 03:16:01 pm »
same here,    dc 24v led strip  they are dual row 1 inch wide  (neutral white), it doesn't change the colors reading if needed
give plenty (maybe too much) of light when put to 24vdc  loll
on a meanwell smps, and a led dimmer + remote,   and i don't have problems  .... if any   i have an adjustable linear version
and yes avoid china  crap ........ far from good
Online Xena E
« Reply #7 on: January 17, 2024, 05:33:42 pm »
Just don't use switchers.
Linear is OK, but a simple solution would be capacitive reactive dropper.
Offline CosteC
« Reply #8 on: January 18, 2024, 07:35:27 am »
Dimmer... I would thing twice before installing any dimmer between PSU and LED strip. Most of dimmers use PWM - naturally rich with harmonics and noise.
Constant Current (CC) instead Constant Voltage (12 V or 24 V in most of cases) is better choice to regulate light output if really needed. Yet this is different design than classical LED strip.
The following users thanked this post: 5U4GB, Randy222
Offline graybeard
  • Retired III-V RF/mixed signal/device engineer
    • Chris Grossman
« Reply #9 on: January 18, 2024, 08:06:16 am »
I just had two Lindgren shielded rooms upgraded to LED lighting because the incandescent bulbs were no longer available.  They installed a shielded DC power supply extensive RF filtering on the inputs and outputs.  Only clean well filtered DC comes into the room.  I have detected no noise from the lights,  I do very low level 1/f and phase noise measurements.
Offline rhb
« Reply #10 on: January 18, 2024, 04:05:49 pm »
I am installing 48x 8' LED lamps in my 1530 sq ft shop building which will get a DIY 11' x 16' screen room with advice from a friend who held a TEMPEST level 2 cert.
I had bought a pair of Corcom 20VB1s on ebay, but was not happy with the performance below 1 MHz.  He suggested using a 6ESB1 in series with a 20ESB6.  That worked much better, but still not to my satisfaction.  As I had the 20VB1s I tried adding one of those.  Placed between ESB series gives really good results up to 5 MHz.  Each string of 3 lamps will have its own switch with 2 strings per 6ESB1 fed via the 20VB1 and 20EBS6 from a master switch so I can choose which lamps come on when I throw the master swtch.
I was using an Agilent 4395A VNA to measure the response of various arrangements and took a *lot* of screen shots.  I'll go through the photos and post a summary showing each filter alone, just the EBS series filters and then the effect of putting the 20VB1 in  between the two.  Interestingly, to be effective the VB must be between the ESB filters.  The VB has a 1.5 M ohm shunt whereas the ESBs are 330 k ohms.  Apparently the impedance mismatch suppresses coupling between the 2 ESB filters.
This is *just* for suppressing conducted mode EMI from the building lights.  The lamps will all have 1/8" hardware cloth screens enclosing them.  The screen room lighting will be a separate effort.
Have Fun!
Reg
« Reply #11 on: January 18, 2024, 05:35:56 pm »
yes for previous thread, i use dimmer  and yes they are pwm,  in my case,  i dont have any problems, i do know their working frequencies  ...  so far all is good,  and the smps and dimmer are enclosed in metal frame
but for sure   it could become a problem is some cases ...
finger crossed
Offline Kim Christensen
« Reply #12 on: January 18, 2024, 07:38:12 pm »
I worked in a place where they had two switches/circuits for the lights. One was incandescent and the other fluorescent for day to day use when low noise was not a requirement.
« Reply #13 on: January 19, 2024, 06:16:31 am »
It'd be interesting to see a few sample shots when you get the time.  I was so concerned about switching noise being radiated from the transmission lines (LED strips) directly above the workspace that I overlooked the fact that EMI hash would be sent back out the mains wires as well.  Are you filtering the output in any way?  A while back I bought a few cheapie "DC power filter" boards off Aliexpress just out of morbid curiosity but they seem to be just low-voltage mains EMI filters (common-mode choke and an LC filter built with cheap low-voltage components) rather than a two-stage LC filter, but this is definitely not my area beyond basic exposure to the theory many years ago.
Offline rhb
« Reply #14 on: January 19, 2024, 02:00:49 pm »
I described both the mains filter and the shielding of the lamps.  What "output" are you referring to?
Edit:
Here are photos showing the pass band of the filter I am using.  The bottom trace is with the 20VB1 between the 2 EBS filters and the upper trace is with the VB followed by the 2 EBS units.  In 4009 you can see that putting the VB between them knocks down the peak at 500 kHz but at the cost of 5 dB at 100 kHz.
I've typically seen the most noise below 200 kHz, so I'm going to be looking to knock down the lower frequencies a bit more.  The best result for either sequence of filters at 100 kHz is only -30 dB, but at this point I need to examine the raw spectrum of the lamps first.  I wish I'd thought to do that before I hung them on the ceiling as the shop is currently unheated and very cold right now.
« Last Edit: January 19, 2024, 03:47:11 pm by rhb »
Offline Randy222
« Reply #15 on: January 19, 2024, 05:48:03 pm »
What type of noise?
Noise you see on the wires, like via FFT?
Or noise like EMI?
Won't even the diodes of a linear PSU make noise as they turn on and off?
For the noise free LED light strip, perhaps used on a workbench when doing certain types of "sensitive" tests measuring, power the LED strip from a battery. When you power off the LED some other charging ckt adds more joules back into the batt, etc.
Another option is, skip DC PSU altogether, just wire two sets of LED's 180deg from each other, then run them using AC (simple stepdown xfrmer to the strip voltage needed). Not sure how much noise they make turning on and off, but when one set goes off the other set goes on. LED rise and fall times should be very fast, so you should have good continuous light, but the on/off flicker from each set does still exist.
Edit: duly noted, in a series of LED's ran by AC, there's still a dead band (albeit small) where the AC voltage needs to rise high enough to fully fwd bias the LED's.
« Last Edit: January 19, 2024, 10:20:44 pm by Randy222 »
« Reply #16 on: January 20, 2024, 01:21:03 am »
The output of the power supply.  You mentioned Corcom filters which are mains (input) filters, I was more concerned about what was coming out of the power supply and into the LED strips.
Offline rhb
« Reply #17 on: January 20, 2024, 01:39:15 pm »
Did you not read "I am installing 48x 8' LED lamps in my 1530 sq ft shop building which will get a DIY 11' x 16' screen room with advice from a friend who held a TEMPEST level 2 cert."?
The EMI filters are to keep noise generated by the LED lamps from getting on the AC power lines in the shop.  That simplifies keeping them out of the screen room.  Each of those lamps has its own SMPS.
I have 1 pair of LED lamps overhead with a single Corcom filter and hardware cloth screening.  Not as good as I'd like, but a huge improvement over not having them.
@Randy222 you need to examine the construction of LED lamps.   EMI is both conducted and radiated.  The Corcom filters are there to suppress the conducted modes on the wire and hardware cloth and EMT to suppress the radiated EMI.
All the AC power to my current bench is fed from a 2.5 kVA Topaz isolation transformer via EMT and MX all the way to the IEC plug at the back of the instrument.  That might seem excessive, but if you probe the EMI coming out the back and bottom of an Instek MSO2204EA you will discover that it is appalling.  I don't see how they ever got it approved  other than  by paying bribes.  The photo shows the general style of the bench AC feeds which are switched or not depending upon whether it should not be shutdown such as a GPSDO or is an instrument which doesn't need power 24/7. So a single switch powers down the bench without having to turn off each instrument one at a time.  With ultimately a pair of 6 bay, 6' high racks filled with T&M instruments, that is a lot of instruments.
As good as the current EMI filter stack is, I don't consider it adequate below 100 kHz which is where most of the SMPS noise is located.  I've contacted Corcom for advice on what to use below 100 kHz, but not gotten an answer yet.  As my goal is -60 dB above 1 kHz, I may well have to design and build custom filters.
The real challenge will be suppressing noise when arc welding as I will have a number of experiments which will run 24/7 for years (OXCO and Vref aging).  10-15 kVA isolation transformers are not common 2nd hand and *very* expensive new.Likely I'll be forced to record the noise when welding and then use DSP to remove it.  The OXCO experiments will be very sensitive to the change in voltage caused by the 50 A welding current.  If necessary, I'll construct a rotary motor and alternator with a heavy flywheel to protect the screen room from the voltage drop.  I installed 165 ft of 4/0 Al for the meter to entrance panel run. That limits the drop at 200 A to 1-2% IIRC.  I'll never pull more than 100 A at any time, so it's a very conservative wire sizing.
Have Fun!
Reg
« Reply #18 on: January 21, 2024, 11:31:27 am »
Yup, which I read as "I'm doing something weird and exotic that doesn't apply for 99.99% of the people reading this", which is why I asked about distinctly non-exotic filtering of the output of a standard SMPS.
Offline rhb
« Reply #19 on: January 21, 2024, 02:31:07 pm »
It applies to anyone using LED room lighting and doing electronic measurements.  With the campaign against incandescents that is becoming *everyone*.  I've got 48 SMPSs running if I turn on all the lights.
The EMI filter in the mains input to an SMPS is not there to protect the SMPS output from being noisy.  It's there to keep the conducted mode EMI from getting into other equipment via radiation from the mains wiring and conducted mode EMI from entering via the mains.
The only exotic part is the screen room.  I mentioned that to convey *why* I am going to the level of effort which I am.  I mentioned that I had advice from a retired TEMPEST technician in an attempt to head off the "you don't know what you're doing" crowd.
Have Fun!
Reg
The following users thanked this post: Randy222
Offline Echo88
« Reply #20 on: January 22, 2024, 07:18:35 pm »
A suggestion: Linear LED panel power supplies instead of SMPS (why produce trouble if you can avoid it), a simple UPS as AC-source during varying mains when arc welding and suitable voltage regulators to power the DUTs: LT3042/3045 instead of series connected selected LM317.
Offline rhb
« Reply #21 on: January 22, 2024, 11:27:11 pm »
I was primarily commenting about the building lighting.  It's quite impractical to replace the OEM SMPS in 48x $18 LED lamp fixtures for a 1530 sq ft building.  Lights in the screen room are another topic, though very closely related.
Arc welding induced voltage drop is an order of magnitude more difficult.  I simply thought I'd share the issues I have and my solutions.  Still waiting for a response from Corcom for which filter to use below 1 MHz.  Might have to make my own.
Have Fun!
Reg
« Reply #22 on: January 24, 2024, 12:56:59 pm »
Don't worry, that's just the demo version for the sales photos, in the version they'll ship the wiring isn't anything like that neat :-).  This one seems to be the original that they're copying.
My motivation for getting prebuilt was, apart from the fact that I'm lazy, or at least have a ton of other stuff that I'd rather be focusing on, is that I can't even buy the parts for the price they're charging for the whole item.  I'm really just after good-enough, not perfect.
For people interested in all the mistakes you can make in low-noise power supply design, PA0NHC has a on this, using Aliexpress units as examples.
The following users thanked this post: rhb
Offline Edison
  • Country: cz
« Reply #23 on: February 16, 2024, 07:17:50 am »
The problem is that my LED strip is not just diodes and resistors, it has blocks of twelve LEDs and each block has its own linear current source, dimming is not possible due to this design.
The light is completely uniform and I don't see a decrease in brightness during use (approx. 10 years).
« Reply #24 on: February 16, 2024, 11:09:15 am »
Could you post more details on this?  That sounds pretty... unusual.
