Author Topic: Electricity Energy/Power measure with Different power factor  (Read 1582 times)
Offline Ashraf AlmubarakTopic starter
  • Country: sd
« on: September 21, 2017, 11:24:26 am »
I am designing a circuit that measures the energy consumed (error must be < 1%), by measuring the voltage through potential divider; and current from shunt resistor. Then these two signals go to ADC inputs of microcontroller PIC18F46K80 to be multiplied and get the power.
The voltage signal enters a potential divider and an amplifier with DC offset and goes to the ADC input. In current measurement circuit the difference between shunt terminals is amplified and then an amplifier with two feedback resistors (NMOS used to select between them to modify the gain) amplify it again. Then go to a DC offset stage after that to the ADC input.
The problem is when the phase change between current and voltage, the energy measurement error changed by 0.8% if the power factor of measured energy changed from 1 to 0.8L.
During my work in this circuit I had come with these notes:
1- Capacitive coupled noise (in the OPAMP negative input) could affect the measurement if the power factor is changed. But in this case, I am sure it is not because I measure the RMS value in the ADC to check if there is a capacitively coupled noise or not.
2- The OPAMP is not 100% inverting, it has some parasitic effects on the phase of the signal that comes to it. It depends on the gain and other stuff.
3- I had some DC blocking capacitor that will make a phase shift (time delay), between voltage and current signal, this phase is very small but it affects the measurement accuracy.
The points 2&3, I have solved it by making small software delay between acquiring the signal of the voltage and the current to compensate for that phase shift/delay.
I have two circuits: The old one works perfectly when the power factor change from 1 to 0.5L. But it suffered from aging of a capacitor as described https://electronics.stackexchange.com/questions/309114/ceramic-capacitance-aging (Ceramic Capacitor Aging Stack Exchange). The accuracy had dropped after 2 months of operation.
 So I have modified the circuit (NEW ONE) by increasing the capacitors and some resistors to minimize the effect of the capacitor aging. But Now I couldn’t even have an acceptable result, though I have tried adding variable delays between reading the voltage and current from the ADC.
New Measurement Circuit Old Measurement Circuit
The Code:
//================== voltage measurement ==================== //
  set_adc_channel(VOLT_CHANNEL);                                               //voltage reading channel
  delay_us(3);                                                           //wait for ADC channel capacitor to charge
  voltage_binary = read_adc();
  delay_us(10);
  //================== current measurement =====================//
  set_adc_channel(Current_Channel);                                           //current reading channel
  current_binary = read_adc();
Differences between two designs:
Item New Design/Old Design
C16 10uF/4.7uF
C7 100uF/47uF
OPAMP TL064ID/TL064INSR
D9 BAS70/BAV99S
Resistor Case Code 1608/2012
R38 100K/18.2K
R35 470K/82K
Sampling rate (Sample/Second) 3400/2700
The Question is: What else could affect the operation of the measurement when the power factor change?
Online MasterT
Re: Electricity Energy/Power measure with Different power factor
« Reply #1 on: September 21, 2017, 02:01:47 pm »
I'd measure magnitude-phase vs frequency for both, voltage and current channel. Basically, power factor is the ratio of the harmonics content, and any mismatch would reflect itself as error in calculation of the power. Also, it wouldn't hurt to check THD level of your amplifiers, if they introduce some measurable level of harmonics on its own.
Do you sample two channels simultaneously?
Is there a HPF in software?  If so, how linear is it in term phase-frequency?
  • Country: sd
« Reply #2 on: September 21, 2017, 02:19:34 pm »
I will Check the THD of amplifier
Q: Do you sample two channels simultaneously?
Ans: No, I sample one channel, wait for acquisition time, then the other channel.
Q: is there a HPF in Software?
Ans: No, no HPF filter, I am using the sampled values directly in the calculations.
Online MasterT
« Reply #3 on: September 21, 2017, 06:34:08 pm »
If you can't sample two channels (voltage-current) simultaneously, than make phase shift by linear interpolation on voltage channel,  something like N->m = (N->m-1 + N->m) / 2.
Here is my code for arduino AtMega328 with linear interpolation and interleaved sampling
ISR(TIMER1_COMPB_vect)
 int16_t adc_value = ADC - adc_Offst;
 static int16_t last_smpl = 0;
 if ( smpl_Nmbr < SAMPL_P )
   if( smpl_Nmbr & 0x01 )
    ADMUX = 0xC5;                     // Voltage, pin AN5
    v_s[smpl_Nmbr >>1] = (last_smpl + adc_value) / 2; //Linear Interpolation
    last_smpl = adc_value;
   else
    ADMUX = 0xC4;                     // Current 3, pin AN4
    c_s[smpl_Nmbr >>1] = adc_value;
 smpl_Nmbr++;
Precise sampling in time is necessary for accurate results, I see delay() in your pseudo-code, it'd be better to drive ADC by one of the timer, and even synchronize timer to AC frequency, running software PLL with x40-50 multiplier.
The following users thanked this post: Ashraf Almubarak
Online Kleinstein
« Reply #4 on: September 21, 2017, 08:07:45 pm »
Many µCs have a free running mode for the ADC. So the ADC speed will set the speed. One than has to use a suitable large number of sampled to get enough averaging and preferable an integer number of periods. If the interval is rather long (e.g. 2 seconds) the exact length is not that important any more.
Even with capacitive coupling it might be a good idea to still consider a possible DC offset to be corrected in software. Ideally it would also warn about too much DC current.
To get close to a kind of simultaneous sampling one could use the average voltage reading from before and after the current reading. Usually the voltage has less higher frequency parts and thus is less effected from averaging. I would guess the µC should be fast enough to do the calculations in real time. So there is no need to store all the data.
The circuit might need shields against capacitive coupling. It is quite high impedance in some areas. To reduce capacitive effects the voltage divider might want a capacitor in parallel to the 470 Ohms resistor.  With a divider ration of a little over 1000 and a parasitic capacitance of maybe 1 pF, this would be something around 1 nF in parallel to the 470 Ohms. As the speed of the ADC is limited anyway better a little more.
  • Country: sd
« Reply #5 on: September 24, 2017, 07:22:52 am »
I have never thought about interpolation/averaging.
I have tried right now and it worked perfectly  ;D.
The next challenge is to ensure that the phase between the voltage and current signal will remain constant and not affected by the aging of capacitors.
Thank you a lot
