Author Topic: Adjusting Signal Amplitude and gain (Without pots in the signal path?)  (Read 1047 times)
Offline RerouterTopic starter
Currently in the midst of creating a little DDS function generator, and could use some input on how best to approach adding offsets and adjusting gain, as the frequencies are a fair bit higher than audio, I felt potentiomers are ruled out.
What i would like is to be be able to control the output offset, over the output range and be able to control the output amplitude from 0.2 - 23V p-p, however I'm also aiming for a cheaper solution (1-$10 is good),
At the moment i am fine with either digital or analog control,
The source is 0.02Hz - 3 MHz (DDS), giving out sine or square, (Lets say up to 40Mhz components)
The output of the DDS is 0.6V p-p
Attached is the circuit i am currently using to amplify the output, FDAC is the filtered output of the DDS, and FOUT is the output to the external world.
Offline seriouscoinage
I used an ordinary 1Kohm potentiometer mounted on the DDS PCB to control amplitude for my 10MHz DDS signal generator, and it didn't seem to cause any problems/bandwidth limitations. I think using long wires to the pot or pots with high resistance values might cause bandwidth issues, but I think a pot should be fine for 3MHz. A variable gain amplifier could be an option if you didn't want to use a pot, and because it can add gain, you might be able to leave out another amplifier elsewhere in your circuit.
Where you attenuating the input signal, in the gain path, or on the output?
I attenuated it in the gain path. I've attached a diagram of the circuit I used in my DDS. The first op-amp provides gain, a 220ohm termination for the DDS filter, and DC offset control. I didn't want adjustable offset, so I just connected it to a trimpot and a voltage reference to null out the DDS output offset. If you want offset control, you can just use a pot on the front panel here instead. The first op-amp drives the 1K pot, and the second op-amp buffers the pot signal, adds more gain, and drives the output. This runs off +/-5V rails and gives 6-7Vpp out.
