Author Topic: Lightbulb dimmer show installation  (Read 3039 times)
Offline bob808Topic starter
« on: May 20, 2017, 05:56:48 pm »
Hello all, A friend needs to set up a light show for his club, and I am trying to find out what kind of gear is needed. As far as I've seen, I think something with DMX512 protocol. The light bulbs are 40W/230V. Needs to be able to dim the bulbs, or create sequences. I presume something with SSR
s? There's a total of 120 bulbs or so. Not a lot of money for pro setup, but I've seen some 16/32 channel dimmers on eba
y. Any recommendations are welcomed.
Offline Cliff Matthews
    • General Repair and Support
Re: Lightbulb dimmer show installation
« Reply #1 on: May 20, 2017, 06:50:22 pm »
Just rent what you need for cheap. No headaches, inventions, fires, or weird hookup problems. Example:
https://www.long-mcquade.com/rentals/pa/0/21/37/#top-pagination-count
« Reply #2 on: May 20, 2017, 11:43:47 pm »
My friend wants a permanent installation for his club. The system will be installed by a proffesional, but we want to do some research before. I'm trying to get a feel for the equipment and cost.
Lights will be light bulbs, no LEDs. Just need to find the type of equipment that controls these light bulbs.
Online BrianHG
Offline james_s
« Reply #4 on: May 21, 2017, 04:00:37 am »
If you want a DIY solution, I designed an all in one board for this several years ago http://www.hoelscher-hi.de/hendrik/english/dimmer.htm using mostly SMD parts. 8 independent channels on a ~100mm square PCB. I can post the PCB files if you want, I built a batch of them I've been using for my Halloween display for years.
Online BrianHG
« Reply #5 on: May 21, 2017, 04:15:17 am »
Just a friendly note.  If there ever is a fire at your friend's club, and he was using home made un-approved electronics plugged into the mains, even if they were not at fault for the fire, his insurance company if they ever discover this during investigation will use it as a reason to deny coverage.
Offline james_s
« Reply #6 on: May 21, 2017, 04:30:13 am »
Hence my attitude that insurance companies are slime.
Offline Towger
  • Country: ie
« Reply #7 on: May 21, 2017, 06:26:08 am »
The NJD DPX12/4 is/was the cheapest 12 channel dimmer you can get off the shelf.  In saying that they changed the design and almost tripled the price of them about 3 years ago.
I have 3 of the older ones and have had no problems with them, with 575W and 640W fixtures.  One has been powered up 24*7 for over 5 years now...
http://www.electrovision.co.uk/homepage.aspx?prod=NJ942&idcode=003300100035#prodtabs-4
« Last Edit: May 21, 2017, 06:33:36 am by Towger »
Offline P90
« Reply #8 on: May 21, 2017, 08:37:09 am »
Oh, by a "proFFesional"... why didn't you say so in the first place...          :D LOL
« Reply #9 on: May 21, 2017, 01:44:12 pm »
professional, changed browser and no auto-correct :)
We're going to hire a company, just wanted to know some reference prices, as people around here like to pump the prices big time, using crap products. I want to learn a few things before we speak to someone just to know what it's all about. I wouldn't take any chances for a commercial venue.
Thanks for the info all!
