Author Topic: Electronic load kit - feature ideas?  (Read 19049 times)
Offline Skimask
Re: Electronic load kit - feature ideas?
« Reply #50 on: January 31, 2013, 12:48:20 am »
It is a bit spendy, which is why I've got all of mine mounted the way I do, in a homemade "case" with a LAN jack on it.  I can move it between multiple projects.
As far as that goes, you can get them smaller, without a touch panel, for quite a bit less $$$.  The interface on a lot of them is the same (if you use the SPI modes) and the code needs a couple of changes to support the differing resolutions.
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline c4757pTopic starter
  • adieu
« Reply #51 on: January 31, 2013, 01:05:18 am »
I'm considering using a character LCD instead. The LED display is pretty limited - currently I have three seven-segment displays to show the number, a couple indicators on the side for things like mA/A, run/stop, and "unregulated" (not drawing set current), and that's it. The only two "messages" it shows on the display are "CAL" and "USb" (gotta love that lowercase B..), as well as a couple of self-test failure codes displayed as "E 0", "E 1", and so on. I'm not a big fan of those character LCDs, but they are certainly more versatile. I'd much rather be able to show "Run calibration routine / See manual", a little "USB" or "RMT" in the corner, "Error - Missing temperature sensor", calculated readings like power as well as current, etc. I think it might be worth the slightly crappy display.
  • adieu
« Reply #52 on: January 31, 2013, 03:19:24 am »
Hmm. Might be a while before this is done. I'm currently in Enclosure and Heat Sink Hell and may end up changing some things around.
Offline Harvs
« Reply #53 on: January 31, 2013, 05:23:36 am »
For low volume things that's almost always the hardest problem.  Compounded when you need to disapate heat.
However, all I can say is take the time and do it properly.  That's what'll set yours apart from all the other "pcb with a heatsink hanging off" type things you can buy out there.  To be honest it wont make much difference to most people if it's 0.5% or 2% accurate, but if it's not in a nice looking case that's ruggard for hobby use with quality buttons and connectors, then forget it.
Offline akcoder
« Reply #54 on: March 24, 2013, 07:41:46 pm »
c4757p,
  Any status update on this project? I'm interested in buying/building a DC load.
-dan
