Most of COTS ESCs have only 2 wires from batteries so cutting ESC's MCU power requires to modify the ESCs. OP's ESC is 60V 160A, it should have a voltage regulator to supply the MCU (60V to 3.3 V, 5 V or ..., linear or SMPS). You can try to add a control signal to the voltage regulator circuit (if possible) to disconnect / disable the MCU supply.
Obviously it would require modifying the ESC, is that not an option?
Technically it is a viable option for hobbyists.
But will it be a viable option for a commercial product, both
both technical and commercial requirements should be considered, e.g.
will it void the ECS warranty
will it require re-testing for safety, EMC, ...
will it pass the reliability assessment
will it be cost effective
will the supplier develop a new model with OP's required safety feature if OP buys few K's per year
