Author Topic: Can you imagine from a picture what this item is used for? My engineer told me i  (Read 5519 times)
Offline NigenTopic starter
  • Country: cn
My engineer told me it might be used for lighting.
Others say it may be used for connectors.
I work for a company that spams forums.
Offline Circlotron
We once used a 96(?) way connector with split bowed pins that could be pressed into a pcb backplane without the need for soldering. Looked similar to that.
Offline HalFoster
Looks like a low-res drawing of a standard 176 pin backplane connector.
--- If it isn't broken... Fix it until it is ---
Offline youngda9
Looks like an airplane seating chart...people packed in like sardines.   :-DD
The following users thanked this post: moffy
