I already took a quick look inside this one (
here and
here) but there was enough reverse-engineering to be done here that I figured it deserved a topic of its own. The story so far is that this device from 1982 generates the audio signal for warning messages in an F-4 fighter jet. I wasn't sure at first if it would have a miniaturized tape player inside, but it does this using a single small board with two 8K x 8 PROM chips (containing sampled audio data), one mystery Analog Devices DAC chip, and two hybrids (one large, one small) which I cut open.
With the help of a local hackerspace's microscope (thanks to the Artisans Asylum open electronics nights!), I managed to ID all the IC dies, and trace out the circuitry inside each hybrid with a combo of the high-zoom photos and a lot of continuity checking with sewing needles. The small hybrid handles interfacing from the outside world, with a lot of clamp diodes and series resistors to protect logic gate inputs from over-voltages in the "wild west" of aircraft wiring. The large hybrid handles the actual logic of sequencing playback of audio samples.
Here's the schematics, also attached below as PDFs for easier viewing:
Ok, so, what's going on here and how does it work?
ClocksThe silver metal can on the board is a 16 kHz oscillator, which feeds the large hybrid. In the top-left corner of the large hybrid's schematic, you can see where it gets divided in half to produce 8 kHz, and then combined in a second flip-flop (U7B) to produce a 90-degree-delayed copy of the 8 kHz clock, to sequence the memory accesses properly.
Clocks at different stages can be gated by external pins, which have pull-up resistors and are connected externally only to the bare-pad testpoints that extend in a row down one side of the board. These testpoints are probably used either for production testing finished units and/or for troubleshooting in the field. An external tester probably uses an edge connector which mates with these rows of testpoints.
One of the 8 kHz clocks is fed to a CD4020 14-bit counter, where the frequency is divided further and further down for other purposes. 16 Hz is broken out to an external pin and sent only to a testpoint, but 8 Hz and 2 Hz are used internally for input & reset timing as we'll discuss next.
Input stages5 different wires come straight into the small hybrid, where each input has a series resistor, clamping diodes, a pull-down resistor, and a filter capacitor (external film caps for some channels, internal ones for others). These inputs all go to logic gate inputs, which we'll look at in a minute. One wire (gray) just goes to a resistor to ground, which might be some sort of external ID or "module present" indication. The small hybrid also contains the voltage divider resistors that set output voltage for the LM117 that generates the +5V supply, mounted off-board on a metal plate.
The red wire and a "ready" signal from the large hybrid get combined and used to gate 3 of the input signals (blue, green, & yellow wires). When either the red wire is low or the "ready" input from the large hybrid is low, the 4011 output (pin 11) is high and all the "received" blue/green/yellow logic outputs are forced high. This essentially disables them, as these signals drive edge-triggered logic within the large hybrid - so the red wire seems to be an "enable" input.
Once these signals go inside the large hybrid, they're de-bounced and short pulses are eliminated by a series of CD4015 shift registers, using an interesting scheme. A low input resets the shift register, while a high input allows a '1' to be clocked further and further down the shift register by the 8 Hz clock. This means that the shift register outputs here only go high (and trigger other downstream circuitry) once the input has been high continuously for a significant fraction of a second. This prevents false-positive triggers from stray pulses, such as EMI-induced voltage spikes in the external wiring.
Power-on resetOne of the channels in the small hybrid is not connected to an external input, but to an RC circuit charged from +5V. This provides a "power-on reset" signal to the large hybrid, where the output (small hybrid pin 22) only goes low after the capacitor (an external film cap on the board) has had enough time to charge. The PNP transistor provides the power-down handling: as soon as the +5V supply dips below the capacitor voltage, the PNP works as an emitter-follower and discharges the capacitor to follow the supply voltage.
The large hybrid dedicates one half of a CD4015 shift register to generating an even slower reset signal, triggered by the small hybrid's "reset" signal and clocked by a 1 Hz clock (derived by dividing the 2 Hz clock from the CD4020 even further). This slower "reset done" signal is what's fed back to the small hybrid, and gates the external inputs via the NAND gates.
DAC & audio outputThe mystery white-ceramic DIP package is a DAC of some kind, with an 8-bit resolution. It gets its data from the PROMs via the large hybrid, and uses a slightly weird op-amp circuit inside the small hybrid to generate an audio output, which is AC-coupled and then exported on the purple wire. There's some weirdness going on in the op-amp circuit & DAC, and I'm not sure what pins 1 and 16 are for on the DAC (pin 1 seems like an output, pin 16 might be feedback to an internal "auxiliary" op-amp?).
It might be a current output from the DAC that gets AC-coupled through the tantalum cap, and then converted to a voltage by the op-amp set up in a transimpedance (I to V) configuration. The small ceramic feedback cap then would provide bandwidth limiting(/stability): it's a weird choice of place to connect that ceramic cap to the current output rather than to the op-amp's inverting input directly, but maybe that made the routing possible inside the hybrid. I'm not sure what the 97Ω resistor to ground is for, then, as it only limits gain. I have no idea then what pin 16 of the DAC would be doing. A voltage output from the DAC would make even less sense though, as its output is fed directly to the op-amp's inverting input.
Either way, there's no non-linear components in here, unless the op-amp is something non-standard and weird - so if there's any audio data compression via log/exponential transfer functions (volume compression), it would have to be happening within the DAC itself.
Audio data readoutThe audio samples are stored in two Signetics MKB36000-series PROM chips, each with a slightly different part number (which is probably a custom part number related to the contents). These are each 8K x 8 bits. The address and data lines of both PROMs are ganged together, and so only one is accessed at a time, determined by which ~CE (active-low Chip Enable) pin is active. From this, it seems like there's only two separate audio samples, one per chip: this is backed up by the National Stock Number data for this voice warning generator:
NSN 6340-01-118-5999
A complete electrical warning unit specifically designed to provide an aural message/warning through pilot's earphones and/or visual message on pilot's heads-up visor display or a control panel indicating an unsafe aircraft attitude, such as: altitude, fire, canopy, pressurization, engine and/or rotor RPMs, etc. Item does not provide facilities for bells, buzzers, horns, sirens and/or lights. Excludes ALARM SET, PERSONNEL HAZARD.
SPECIAL FEATURES VOICE WARNING GENERATOR PROVIDES VOICE WARNING TO THE PILOT WHEN ALTITUDE IS TOO LOW AND WHEN THE CANOPY IS NOT SECURED
III FSC APPLICATION DATA AIRCRAFT ALARM,SIGNAL SYSTEMS
MANUFACTURERS CODE 12464
DESIGN CONTROL REFERENCE A05A0241
Because the CD4040 address counter is clocked by the 8 kHz clock, this shows the audio is sampled at 8 ksps, and each audio clip is about 1 second long.
In the top-right corner of the large hybrid schematic is a counter, connected to the PROM address pins, and an 8-bit latch between the PROM output data and the DAC input. When there's a rising edge on the white wire or the blue & green wires, this latches the output of U2A high, and through a chain of OR gates, brings the "Playback" signal high. The high "Playback" signal allows the address counter to cycle through the PROM's entire address space; at the same time, it also enables the 8-bit data latch (built out of a CD40174 and a CD4013) which latches the previous PROM data output for the DAC.
When the address counter reaches the end of the address space and rolls over, the highest bit goes low, and so this creates a rising edge via U4A's ~Q output to create a "Playback Done" signal. This "Playback Done" is used to reset U2A and essentially turn off playback mode when the sample is done playing.
The "Playback in progress" signal is sent to a mystery chip in the large hybrid, which has what looks like a couple large power transistors.
The probable-output from this mystery power-driver chip is then sent out through pin 58, and to the white/brown wire to the external connector (protected by a TVS diode). This seems to be a "audio playback in progress" output signal to some external equipment and/or for troubleshooting, maybe to avoid trying to trigger a playback while one is already in progress.
Sample selectionThe yellow wire seems to select which audio sample to play. A rising edge on the yellow wire sets U3B's output high, and from there a strange series of events happens with U3A and U2B, but as far as I can tell it seems to end with U13C's output being a "sample select" signal. This "sample select" is fed both inverted and non-inverted to two large AND gates, each of which drives one of the PROM Chip Enable signals, to select between the two PROMs. Because the MKB36000 PROM uses an edge-triggered I/O scheme, where read operations are started by a falling edge on Chip Enable, the 8 kHz clock is one of the inputs to both AND gates so that the selected Chip Enable signal is re-asserted every clock cycle.
The logic around the playback sequencing and the yellow wire is pretty twisted and I haven't worked through it in detail, so I'm not entirely sure what's going on there...
...but it looks like in the D-flip-flop-spaghetti there might be accommodations for the yellow wire going high while a sample is already playing, and triggering a playback of the second sample once the first has finished playing. That's my surface-level read on what U3A/U14C/U2B are doing.
Making it workSo of course, the goal is to get it to play back the stored audio! I powered up the board first with 9V, then with 24V (as 28VDC is a standard aircraft requirement): it drew a few mA, and the +5V power supply was accurate. I tried pulling the red wire to +5V while pulsing various combinations of the white and yellow wires while watching the purple audio output on my scope, but couldn't get any response out of it. Unfortunately, when I tried to carefully probe inside the large hybrid to see if the 16 kHz clock was active, my hand slipped - the scope probe's ground ring slipped and touched
something, and now it won't turn on anymore without excessive current draw. On a bench prototype I'd usually be soldering wires and loops everywhere to prevent exactly this kind of thing from happening, but it's all covered with conformal coating here (and I want to disturb it as little as possible, outside of removing the hybrid lids).
Since it seems like I've fried something inside the large hybrid, the next backup option is to read out the memory data directly. I can cut the large hybrid's bond wires for the external pins that lead to the PROMs (and the +5V pin, so it doesn't drag down the board's 5V power), and connect a bunch of little test clips to the large hybrid's PROM pins on the inside, then use my trusty Batronix programmer to read the PROM data as long as a similar-enough model is supported. It's more of a pain, but such is the price of shaky hands I guess.
