I like cheap Asian electronics modules; I have learned a lot testing, troubleshooting and even sometimes repairing them. I always buy them two or more at a time to raise the odds and have a ready comparison board if I do run into a problem and replacement components may cost much more than the whole module. If both are bad, they sometimes are bad in different places.
My rules of thumb are:
• Never expect to get instructions unless the listing specifically states it is included. If you do get an instruction sheet then deciphering it could be another challenge.
• Any reverse engineering is usually only in relation to fixing or upgrading a module
• Buy modules with at least double the rated maximum power I expect them to ever see
• I skip over items with listed specs that are obviously exaggerated way beyond what I can tell is bogus by looking at the pictures of the boards.
I look for heat sink area, number of filter caps, etc. and will pay a little more for something similar that looks to be higher quality (but it is sometimes hard to tell).
• I have found that fleaBay is often faster and more reliable than Ali Express especially if it is shipped from Hong Kong --- Malaysia and Singapore usually are slower.
• I also search for the same item from many sellers and copy pictures, instructions and any connection schematics to a file for future reference. Sometimes a module will no longer be listed by the time it arrives and making a reference sheet at the time of ordering saves headaches later. Many of the better sellers have found out that including some diagrams with the listing helps sell their modules; I’ll pay a bit more because of the listing quality. Another advantage of making up these reference sheets is that it is easy to add my own notes as to failure mode; how much I tested the module and for how long etc.
