Author Topic: Differential probe  (Read 1660 times)
Offline GGMMTopic starter
Differential probe
« on: May 13, 2023, 07:05:54 am »
Hello,
Good morning,
I’m thinking about making a differential probe.
Since I have BF988S in advance, I’d like to use them.
However, I would like to know the function of the 5 transistors on this diagram. It's similar and does not exist on the D.Kramniks probe.
 It is not to light a led. LOL
Another modification, I want to find another op amp for the output, to gain bandwidth.
your opinions
cdt
Re: Differential probe
« Reply #1 on: May 13, 2023, 07:07:52 am »
other pictures
Online mk_
  • Country: at
« Reply #2 on: May 13, 2023, 07:12:49 am »
Search TI`s collection of opamps and related parts
other pictures
Kramniks Design is "only" AC
Offline tggzzz
« Reply #3 on: May 13, 2023, 08:39:17 am »
They are a current source for the differential amp above your red outline.
The LED and Q2 form a temperature compensated current source, with the current (~150µA) coming out of Q2 collector.
U2A and Q20 form a basic 2:1 current mirror, and Q1 "turns" that into a Wilson current mirror with the current (~300µA) coming out of Q1 collector. Both are described in wackypedia.
« Last Edit: May 13, 2023, 09:37:08 am by tggzzz »
The following users thanked this post: boB
Offline moffy
« Reply #4 on: May 13, 2023, 08:47:37 am »
The red section is a PNP current source using Q2 and the LED as a temperature tracking reference. The three transistors from the LM3046 and Q1 form a current mirror with I think twice the current going out as is coming in. The current mirror requires very little voltage drop, basically 2Vbes to operate, so it allows the input stage to operate over a wider voltage range.
« Reply #5 on: May 13, 2023, 08:53:45 am »
Hello,
Thank you for your answers.
So actually the diode is not a gadget. Lol
I put the link for the explaination
cdt
https://en.wikipedia.org/wiki/Wilson_current_mirror
« Reply #6 on: May 13, 2023, 09:09:15 am »
Hello MK_
I’m more inspired by that.
https://www.diyaudio.com/community/threads/differential-probe-reverese-engineered.248505/
Can you tell me if the DC passes, or possibly what changes need to be made.
Also the fets will be replaced by BF998 (As explained, for a few euros you have more than 10)
So surely modify some resistor
Schematic will be a lot of inspiration of the 2 design
cdt
Offline tggzzz
« Reply #7 on: May 13, 2023, 09:42:35 am »
You are considering how it works.
As it is a high voltage differential probe you will also need to consider how it fails. That should include:
  • appropriate PCB layout, material, and shape (possibly including slots/cutouts)
  • appropriate resistor types; some are more suitable for HV operation and others
  • ditto capacitors
https://www.diyaudio.com/community/threads/differential-probe-reverese-engineered.248505/post-3765125
« Last Edit: May 13, 2023, 09:46:20 am by tggzzz »
Offline daisizhou
  • Country: cn
« Reply #8 on: May 13, 2023, 09:52:49 am »
daisizhou#sina.com #=@
Online mk_
  • Country: at
« Reply #9 on: May 13, 2023, 09:54:03 am »
Hello MK_
what kind of diffprobe you need/want to build? a fast one, low voltage or a slower one with hV?
« Reply #10 on: May 13, 2023, 05:16:17 pm »
Re,
Do you have an explanation that on the Kramniks version 2 probe, we went from +/-5V to +/-3.3V to power the op amp?
This implies a circuitry with converter and 2 additional regulator.
why?
cdt
Online mk_
  • Country: at
« Reply #11 on: May 13, 2023, 06:24:37 pm »
Re,
Yes, but if it is needed... then it has to be done, whats the problem?
why?
I have no idea why Kramnik he decided to go that way.
I design my own probes for max. outputvoltage and therefore I generate the supplyvoltages as needed by the design.
« Last Edit: May 13, 2023, 06:30:45 pm by mk_ »
« Reply #12 on: May 13, 2023, 07:03:10 pm »
Re,
it's good.
You have to read the article to the end.
He had too much noise on the power supplies
https://xellers.wordpress.com/electronics/1ghz-active-differential-probe/
cdt
Offline daisizhou
  • Country: cn
« Reply #13 on: May 15, 2023, 03:47:02 am »
Hello,
Good morning,
your opinions
cdt
Looking forward to sharing it after your success
