Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
vertical right angle slider switch array
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: vertical right angle slider switch array (Read 1179 times)
stern0m1
Contributor
Country:
on:
June 24, 2018, 03:42:17 am »
Im looking for a switch like this, but an array of 4. 1 piece with 4 switches
Vertical right angle slider.
Anyone come across something?
Thanks
Logged
ebastler
Super Contributor
Country:
Re: vertical right angle slider switch array
Reply #1 on:
June 24, 2018, 07:13:48 am »
Does it have to be
DPST
SPDT? If a simple on/off switch is sufficient, angled DIP switches are widely available. (But may also be a bit smaller than what you had in mind?)
Edit: Fixed the mixed-up switch designation...
Last Edit: June 24, 2018, 04:36:59 pm by ebastler
Logged
stern0m1
Contributor
Country:
Reply #2 on:
June 24, 2018, 04:09:09 pm »
I need an on on switch. A switch with two positions each position connects 1 pin to a different one.
Thanks
Logged
rdl
Super Contributor
Country:
Reply #3 on:
June 24, 2018, 04:23:23 pm »
Switches like the one in the picture exist and should be easy to find, but an array of four may be impossible to find outside of custom made. What do you expect to gain with an array vs. four single switches side by side?
Logged
stern0m1
Contributor
Country:
Reply #4 on:
June 24, 2018, 04:35:22 pm »
Price. The cheapest I found for a single switch was 65 cents us. The only switch I found at all this style was from
http://www.dailywell.com.tw/
If you know of others please tell me.
Thanks
Logged
rdl
Super Contributor
Country:
Reply #5 on:
June 26, 2018, 10:05:21 am »
Apparently those vertical style switches are pretty expensive, $3-$4. You might consider using the cheaper type and mounting them on a small piece of pcb attached vertically to the main pcb. I have seen this done in commercial products with 7 segment displays.
Some ideas maybe here:
https://www.eevblog.com/forum/projects/mount-pcbs-together-in-a-90-angle/
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
