I'm building a small custom USB 2.0 hub for a project, and one thing I'd really like is to include ESD protection on the user facing ports. Needless to say there are a *lot* of parts out there catering to this application...
The more interesting parts are the "all in one" protection devices. Usually a 6 pin IC that offers ESD protection on both data lines, and optionally protection for the Vbus line. Given I'll be hand assembling this, I figure this will be easier than dealing with micro-sized chips for each line. Especially considering my hands aren't as steady as they used to be. So far I've found the following parts:
Onsemi - CM1231-02SONexperia - IP4234CZ6Bourns - CDSOT563-0502Bourns - CDSOT236-0502I'm sure there are more like these, I just haven't found them yet.
What should I be looking out for when picking one of these protection arrays? I know I want to minimise capacitive loading on the data lines, but all these parts seem more or less the same in that regard. And on the plus side I'm only looking at USB 2.0. The Bourns parts lack a series resistor, and there are some other circuit differences between them, but that aside they seem to be about the same to my untrained eye...
Are there any other parts I might want to look at/avoid?
Thanks for any advice you can give!
