Red_Micro,
This analysis is wrong!!
The REF pin on the LM4041 is referenced to pin 2, the cathode.
Ignore
I think you need to revisit this part of the circuit:
With the component values shown, the LM4041 will try to regulate TP9 at
V
TP9 = 1.225V (1 + R33/R35) = 1.225 (1+ 30K/10K)= 4.9V
This can't happen because you only have a 3.3V supply.
To regulate mid-rail, 1.65V
Make
R33 = 10K
R35 = 30K
V
TP9 = 1.225 (1 + 10K/30K) = 1.633V
(With the original values, the voltage on TP9 = 3.3 x (10K +30K)/ (10K + 30K + 3.3K) = 3.05V )
In addition this circuit is a shunt regulator, it has limited ability to source current. You need add a bypass capacitor from TP9 to ground.
Regards,
Jay_Diddy_B
