Author Topic: ESP8266 breakout boards with buttons reset and flash ?  (Read 2904 times)
Online kripton2035Topic starter
« on: December 03, 2017, 03:56:02 pm »
I bought some esp8266-12 and some white breakout boards.
but these boards are not as I want. I almost always need a reset and a flash button on it.
so I drilled these boards, installed 2 buttons, some resistors and voilà.
but it takes time.
I searched on ebay but did not find any simple breakout boards with 2 buttons, eventually with a 3v regulator.
it exists but for the esp32.
does anyone have a link for such a board ?
thanks.
Offline gsuberland
Re: ESP8266 breakout boards with buttons reset and flash ?
« Reply #1 on: December 03, 2017, 04:03:15 pm »
Have you looked at the NodeMCU? They've got flash and reset buttons, plus USB for programming. You can pick them up on eBay for almost nothing.
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
« Reply #2 on: December 03, 2017, 04:20:34 pm »
You basically get the Wemos D1 mini clones for 3€ delivered from eBay - They feature a reset button and USB <-> TTL interface etc. Why bother with those breakout boards?
He’s like a trained ape. Without the training.
« Reply #3 on: December 03, 2017, 04:21:35 pm »
yes but all I found already had the esp8266 on the board. and I have already the esp8266...
« Reply #4 on: December 03, 2017, 04:24:03 pm »
the wemos d1 boards only have the reset button . how do you flash them ? is it automatic or do you need a flash button, you put on the pcb ?
Offline frozenfrogz
« Reply #5 on: December 03, 2017, 04:33:27 pm »
You don’t need to boot them into flash mode as with the ESP32.
Simply connect via USB and upload your sketch. (I am using the Arduino IDE and ESP board manager)
Regarding other break out boards I guess the options are limited. You would either design your own PCB that features an ESP8266 as a component or you get one of those Wemos / NodeMCU / whatever dev boards, since getting a break out board and ESP8266 module is about the same cost as getting a readily assembled unit with serial interface and all that. Maybe on Alibaba / Aliexpress there are more variants.
Offline TJ232
  • www.esp8266-projects.org
    • ESP8266 Projects
« Reply #6 on: December 04, 2017, 08:09:50 am »
If you need PCB's only, I have done a while ago some related ones. You can order them directly from DirtyPCB.
1. nEXT Evo board: a full ESP8266 board, you can have a nice small all-in-one module with nEXT Bus connector (I2C) for easy adding exending modules: http://dirtypcbs.com/store/designer/details/6858/525/esp8266-cbdb-next-evo-devboard
Bonus, a secondary nEXT AN-1 Analog Extesion Board PCB that brings you a 18Bit ADC (autoscale 0-40V input!), 4x12Bit DAC, Precison Temperature measurement, 8bit I/O port, etc.
Related article here: ESP8266 nEXT EVO Board - general view
2. For just a very simple ESP8266 adapter, you can use half of the MPSMv2 PCB, available also here at Dirty PCB:
http://dirtypcbs.com/store/designer/details/6858/355/esp8266-wifi-web-power-switch-for-mains-mpsm-v-2-d
I must admit that I've use it a lot as a quick ESP adapter :)
Related article:  MPSMv2 - Power Switch General view
Happy breadboarding,
TJ.
ESP8266 Projects - www.esp8266-projects.org
MPDMv4 Dimmer Board available on Tindie: https://www.tindie.com/stores/next_evo1/
The following users thanked this post: kripton2035
