Author Topic: Should my design use Stripline in USB differential pair impedance calculation?  (Read 5019 times)
Offline sfcircuitTopic starter
  • Country: my
I am designing a PCB that involves USB 2.0 differential pair trace. It is a 4-layer board with the following configuration:
Top layer: Analog and low-speed digital signal
Layer 2: 3.0V Power Plane
Layer 1: USB2.0 Differential pair trace
Bottom layer: Ground Plane
According to this: http://www.bitweenie.com/listings/microstrip-vs-stripline/
A stripline is in between 2 Ground planes, however in my design, the USB2.0 differential pair is in between a Power plane and a Ground plane instead.
I am planning to use "Saturn PCB Design - PCB Toolkit" to do differential pair impedance calculation. However, I am not sure which type of differential layer should I use:
1. Edge Cpld Ext (Microstrip)
2. Edge Cpld Int Sym (Edge-Coupled Symmetrical Stripline)
3. Edge Cpld Int Asym (Edge-Coupled Asymmetrical Stripline)
4. Edge Cpld Embed
5. Broad Cpld Shld
6. Broad Cpld NShld
Can my design still be considered as a Stripline for impedance calculation? Or should I select another one.
Thank you.
Cheers.
« Last Edit: January 28, 2018, 07:39:27 am by sfcircuit »
Offline ataradov
    • Personal site
How long are your USB traces? If they are under 2-3", then just route them as your normal traces. USB 2.0 is not that picky. Just look at any product or a development kit - people jump between layers, route around stuff, and it all works in the end.
Alex
  • Country: my
Thanks for your advice Alex. Yes, they are just around 1.5", separated by a USB 2.0 switch in between. Unfortunately, my project (a PCB to connect between a smartphone and laptop, a current measuring meter) had signal integrity problem, at a very specific situation, which it failed when a USB 3.0 phone is trying to connected to a USB 2.0 laptop port, it works fine for USB3.0 laptop port and USB 2.0 phones. I tried to troubleshoot, and I suspect it might be due to length mismatch of the differential pair. Also, before I dive into the next design, I am trying to rule out all possibilities including the impedance mismatch.
Hence, I hope to find out whether how should I calculate the impedance for this design (due to design constraint, the USB 2.0 trace has to be between a power plane and a ground plane).
« Last Edit: January 28, 2018, 10:53:34 am by sfcircuit »
Offline Leo Bodnar
If you are trying to tightly-couple them consider the fact they are not true differential signals.
Each packet ends with two bit long SE0 state where both lines go low (SE0 = single-ended zero) so mind the return path(s)
In general - don't overthink it unless you are worried about radiated EMI.
Leo
Offline ataradov
    • Personal site
What is USB switch? Are you sure it is working correctly? Can you bypass it for a test?
USB 3.0 devices start talking in USB 2.0 mode until they fully understand that host is USB 3.0. I don't think it is a signal integrity issue, it must be something else, especially given that true USB 2.0 devices work fine.
I really don't know how to do actual calculations, but if you won't find anything useful, then just make traces a bit wider (20-30 mil). It looks like that's what typically happens when you try to do proper matching anyway.
Alex
  • Country: my
Leo
Alright, thanks Leo. It seems like USB 2.0 is pretty straight forward.
  • Country: my
The switch I am referring to is a basically a multiplexer: http://www.mouser.com/ds/2/149/FSUSB30-1010253.pdf
And yes, I am able to bypass it. Regarding making the trace wider, may I know why so?
Thanks.
SF
Offline ataradov
    • Personal site
I would definitely try to bypass that switch first.
I have not seen calculations for USB specifically, but that's what happens when you try to do impedance matching for RF and other stuff - traces get wider on standard PCBs. At least that's what I would do in this case, but I never had problems with 10 mil traces either.
Alex
Offline NiHaoMike
    • Facebook Page
Check if the connection seems to be sensitive to slight movement. I have seen issues with a USB 3 network adapter having problems working with a Raspberry Pi because of that problem.
Offline T3sl4co1l
    • Seven Transistor Labs
A power plane is a ground plane, for RF / transmission line purposes, if it is significantly larger than the trace in question, contiguous over the length of the trace, and well bypassed to ground.
Seven Transistor Labs, LLC
Offline tan98010
Edge Cpld Ext (Microstrip) might be a good choice, it will be a "good practice" to route all the USB connection in 90ohm.
As an alternative you could use "co-planar wave guide" if you have ground pour beside your diff pair.
  • Country: my
Hi Tim, yes, the power plane is significantly larger than the differential signal and almost the same size as the ground plane. I will try the edge-coupled stripline calculation. However, I don't quite understand what do you mean by "well bypassed to ground".
  • Country: my
Hi tan,
Thanks for your suggestion. My design however has already a crowded slow signal trace on the top layer, I have no choice to route the USB differential trace on the third layer. Regarding the "co-planar wave guide", my design have no ground pour beside the differential pair.
Offline ejeffrey
Basically it means that you have plenty of capacitance between the power and ground plane in all the right places.  That creates a low AC impedance between the planes and for the purposes of AC signals makes them equivalent.
"all the right places" means (basically) wherever your high speed signals begin, end, or change layers.  Begin and end are usually easy, as these are the "standard" local bypass capacitors you place on any ICs.  But if your signal goes through a via from top to bottom you need a bypass cap between the two internal planes as close as possible to the via.  There are a couple cases where you might get tripped up on the bypassing at the signal beginning or end.  One would be of the begin or end is a passive component (such as a connector) that doesn't have a power connection and wouldn't ordinarily need a bypass capacitor.  The second is if you have multiple power planes, and the one near the signal trace is not the one that powers the chip that produces/consumes the signal.
In addition if you have split power planes and you need signals to cross the split, you should have capacitors bridging the gap near the signal crossing.
  • Country: my
Hi ejeffrey,
Thanks for your detailed explanation. I do have a split plane where the signal needs to cross over, I will try to remove it or get some caps on it.
