Author Topic: Looking for 5 mached transistors array on one silicon chip IC  (Read 1459 times)
Offline 001Topic starter
  • Country: aq
« on: September 07, 2018, 10:34:39 am »
Hi
i`m looking for IC what consist of at least 5 mached npn transistors on one silicon chip for termostability reason
hfe about 50-250 and few mA collector current will be ok
Dip or SOIC package will be ok too
Any opinions?
« Last Edit: September 07, 2018, 10:42:21 am by 001 »
Offline flash2b
Re: Looking for 5 mached transistors on one silicon chip IC
« Reply #1 on: September 07, 2018, 10:39:53 am »
CA3086
They say attention is a shovel. It's time to dig 'em out.
The following users thanked this post: 001
Online oPossum
Re: Looking for 5 mached transistors array on one silicon chip IC
« Reply #2 on: September 07, 2018, 10:49:43 am »
  • Country: aq
« Reply #3 on: September 07, 2018, 11:16:41 am »
Thanx a lot!
I`m really need for few transistors on ONE silicon chip
How to understand what IC consist of ONE chip vs simply 5 discrete transistors in one package?
Online oPossum
« Reply #4 on: September 07, 2018, 11:28:32 am »
Monolithic means everything is on a single piece of silicon. All the parts listed above are monolithic.
  • Country: aq
« Reply #5 on: September 07, 2018, 11:33:44 am »
And say me about arrays marked 3904 2222
is it simply plastic package for four different 2n3904 or 2n2222 transistors or it is also one monolitic chip?
Online MK14
« Reply #6 on: September 07, 2018, 12:20:59 pm »
Best to check the datasheet for the devices you are interested in. That should tell you how well matched the parts are.
Usually, they are a monolithic chip, but there sometimes are devices constructed out of multiple parts (hybrids, but they could still be matched parts, especially with very old electronics stuff, when matching parts e.g. transistors, was not uncommon). So checking the datasheet is best.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #7 on: September 07, 2018, 05:55:53 pm »
3904 etc. were never monolithic array designs.  If they don't specify "monolithic", they are singulated dice.
Some are available with dice matched as well as monolithic arrays, but they won't track thermally so you need to use them more carefully for the same purposes.
Seven Transistor Labs, LLC
Offline MT
  • Country: aq
« Reply #8 on: September 07, 2018, 09:50:23 pm »
Basically all 5 tranny arrays are obsoleted 3083, 3086 etc etc etc, however you can still get LM3046 but they are EOL by TI.
