Author Topic: ESR meter with extended scale.  (Read 694 times)
Offline ietTopic starter
  • Country: cz
« on: April 24, 2024, 04:04:18 pm »
Basic information here.
https://electronicsdesignfun.blogspot.com/p/esr-meter.html
The meter is adapted to the tester body.
The front panel contains a zero regulator, a power switch, and a graduated scale. The calibration was done using SMD resistors with low inductance.
Scale: 0.005-5 Ohm.
Some changes have been made to the original scheme.
U1-LM833
Resistors:R4-5.6k,R5,R6-0.1,R8-20k,R11-100k
D1,D2-1N5817
The transformer is wound on a ferrite ring
Supply voltage:9v
Frequency:100 kHz
Vpp:100mV
The following users thanked this post: kripton2035, BILLPOD
Offline enut11
  • Love building/modifying/restoring test equipment
Re: ESR meter with extended scale.
« Reply #1 on: April 25, 2024, 10:16:31 pm »
Interesting adaption for an old analog multimeter. How does the scaling work?
an electronics nut from wayback...
  • Country: cz
« Reply #2 on: April 26, 2024, 02:34:34 pm »
The values on the ohms scale of the multimeter are indicated in red.
The ESR values in mohms are indicated in blue.
The following users thanked this post: enut11
  • Country: cz
« Reply #3 on: April 27, 2024, 05:41:47 pm »
As you know, the ESR of a capacitor can react to the heat of your hands. And the result may not correspond to the actual value. In addition, to obtain the most reliable result, very reliable contact between the probes and the legs of the capacitor is necessary.
Therefore, a simple device was made to install and measure the ESR of capacitors.
  • Country: cz
« Reply #4 on: Yesterday at 09:59:35 am »
I made a small modification to the ESR meter.
I used larger cross-section wires. I used elements with greater temperature stability in the 100 kHz generator circuit. Previously, the generator frequency drifted to 100-200 Hz during several hours of operation. Now the frequency is stable at 100 kHz.
