Author Topic: ESR of a boost converter output capacitor  (Read 1637 times)
Offline Mat219Topic starter
  • Country: cz
« on: January 28, 2020, 08:04:46 pm »
Hi.
I'm trying to design a 200V boost converter for nixie tubes based on this schematic : https://threeneurons.wordpress.com/nixie-power-supply/hv-supply-kit/
But i don't know if my output capacitor will be good for the job. Is the capacitor ESR important for a boost converter design? And what are the effects of it?
Thanks for your time everyone.
Offline Dmeads
  • who needs deep learning when you have 555 timers
Re: ESR of a boost converter output capacitor
« Reply #1 on: January 29, 2020, 06:43:33 am »
With only 5W of output power, it shouldn't be a super bad issue, but still something to take into consideration. I was building a 300W Boost converter where ESR was a HUGE deal due to output ripple current and power dissipation. (I blew up more than a few capacitors haha).
I dont believe ESR will effect the output voltage much (may cause a little ripple), but it could effect the current more.
These tutorials were a great help to me: https://www.powerelectronicsnews.com/technology/the-dc-dc-boost-converter-power-supply-design-tutorial-section-5-1
some of stuff went over my head but some really did help me. Maybe it can help you out too.
What I would do I calculate the ESR of your cap, then throw it in a SPICE simulator, and model it with the calculated ESR and other values. I can help you if you have LTSPICE or TINA-TI or PSPICE. See what happens at the output.
To calculate ESR, you have to look at the datasheet of your cap. If it is electrolytic/aluminum, it might have the ESR listed, if not, look for the "tan(δ)" parameter. This is called the dissipation factor or DF. Then calculate ESR from this link: https://www.illinoiscapacitor.com/pdf/Papers/impendance_dissipation_factor_ESR.pdf
let me know what happens. you can send a message if needed cuz i dont check the beginner forum a whole lot
The following users thanked this post: Mat219
  • Country: cz
« Reply #2 on: June 11, 2020, 12:24:35 pm »
Thanks for the help.
I tried putting 10 ceramic capacitors in parallel at the output and if my simulation is correct, then it should be able to handle somewhere around 30W-50W at like 80-90% efficiency (Using the LT3759).
Now I'm waiting for the parts to arrive and then I can start testing and hoping something doesn't blow up.
Offline Dmeads
« Reply #3 on: June 13, 2020, 04:31:55 am »
Happy to help :)
