Author Topic: ESR of ceramic caps  (Read 689 times)
Online ricko_ukTopic starter
ESR of ceramic caps
« on: July 26, 2020, 10:19:24 pm »
ceramic capacitors datasheets do not seem to provide any ESR values (at least those I have been looking at).
1) Why is that?
2) what are some min/max/range values?
Thank you :)
Offline dmills
Re: ESR of ceramic caps
« Reply #1 on: July 26, 2020, 11:21:07 pm »
They generally quote D.F. instead, but sometimes you have to hit the manufacturers part specific site for it.
See for example https://product.tdk.com/en/search/capacitor/ceramic/mlcc/info?part_no=C3216X8R2A104K115AE&utm_source=mlcc_commercial_soft_en.pdf&utm_medium=catalog
Regards, Dan.
The following users thanked this post: ricko_uk
Offline bob91343
« Reply #2 on: July 26, 2020, 11:37:14 pm »
DF is a more relevant parameter than ESR.  It includes dielectric effects and, in any circuit, the DF is the important thing.
Self resonant frequency helps to estimate ESL.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: July 27, 2020, 12:04:41 am »
ESR depends on frequency.  What frequency did you want to know about?
For most types, DF is fairly stable, until approaching resonance.  This can be seen on the impedance plot as resistance falling at the same rate as reactance, but always staying some fraction of it (that ratio being DF).
A wideband model might represent this effect with a diffusion network: a dominant capacitance with R+Cs in parallel, having geometrically spaced R and C values.  (Physically speaking, these might correspond to distributed loss elements in the dielectric -- dipoles of random size and relaxation time, which happen to be distributed smoothly enough to give what looks like a constant DF.  The actual physics need not bear any relation to this model though -- it's just a model, don't read into it too deeply.)
Many manufacturers have databases including calculators to generate SPICE models; beware that they usually account for only a few of these effects, i.e. the model is still calculated around a frequency of interest.
Seven Transistor Labs, LLC
Offline sourcecharge
« Reply #4 on: July 27, 2020, 01:26:14 am »
If loss tangent or tan(0) is given they are equal to DF....
ESR = DF^2/(1+DF^2) * 1/(2*pi*F*C*DF)
« Reply #5 on: July 27, 2020, 05:37:46 am »
Thank you all, that clarifies things. :)
