Author Topic: Ethernet TTL Direct Connection  (Read 883 times)
Offline ricko_ukTopic starter
« on: April 17, 2020, 05:22:51 pm »
is it possible to connect 2 micros on the same board to each other using Ethernet connection?
Obviously placed only few mm apart from each other and obviously using matched length/impedances traces.
If so then anything should I be aware or careful about in the design?
Thank you
Offline donotdespisethesnake
  • Embedded stuff
Re: Ethernet TTL Direct Connection
« Reply #1 on: April 17, 2020, 05:52:36 pm »
By "Ethernet TTL"  I guess you mean MAC to MAC, rather than PHY to PHY. I believe MAC connection is possible with a RGMII interfaces, can't say I've ever seen it done though.
Bob
"All you said is just a bunch of opinions."
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: April 17, 2020, 05:55:28 pm »
AFAIK, yes, you just need to swap the RX/TX lines much as you'd connect a UART.  I haven't done it but I've ran across a few appnotes that seem to cover it.
Seven Transistor Labs, LLC
Offline David Hess
  • DavidH
« Reply #3 on: April 17, 2020, 09:37:54 pm »
It is definitely feasible.  Between boards or chassis where there may be a ground difference, the signals can be AC coupled.
Offline T3sl4co1l
« Reply #4 on: April 18, 2020, 01:03:07 am »
Do you mean MDI?  Yes, that works, just use pullup resistors and coupling caps, no transformers needed -- or just the one transformer for better isolation than capacitors.  (To clarify, coupling capacitors alone, works for small ground-to-ground offsets: maybe fractional volts at AC, up to say tens of volts at DC.  Whereas the transformer gives very low isolation capacitance, allowing much more freedom at both AC and DC.)
For MII, I don't know that it can be AC coupled?
Offline David Hess
  • DavidH
« Reply #5 on: April 18, 2020, 11:50:01 pm »
I mean for MDI and there are application notes discussing it.
