Author Topic: K-Type Thermocouple Spice Model  (Read 2767 times)
Offline veryevilTopic starter
« on: February 09, 2019, 11:25:40 am »
Hi, I'm looking for a spice model (LTspice preferably)  for a K-type thermocouple.
Anyone have one or clever enough to make one from NIST tables?
Cheers
Online T3sl4co1l
    • Seven Transistor Labs
Re: K-Type Thermocouple Spice Model
« Reply #1 on: February 09, 2019, 10:59:10 pm »
How would you want that, with a TEMP input pin?  Otherwise you have to specify device temp which is really only usable with parameter sweeps I think...
Have you looked around for one?  Wouldn't surprise me if it's out there for free, it's easy enough.
I could write one but it'd be a few hours work writing and testing... maybe someone else here has the spare time to?
Seven Transistor Labs, LLC
« Reply #2 on: February 10, 2019, 03:15:35 am »
Hi, the only one I could find was a J type. I managed to modify it with the correct polynomial for a k-type and it's working.
I was going to post it on here but forum was out most of yesterday.
When I get back to my computer I'll post it.
Thanks
« Reply #3 on: February 11, 2019, 08:12:17 am »
* K-Type thermocouple subcircuit for LTSpice
* Using reference function on ITS-90 (International Temperature Scale of 1990)
* Temperature range: -270.000 to 0.000 degC
*                       0.000 to 1372.000 degC
*            Tjunc = Input voltage representing the thermocouple junction temperature
*            | Tref = Input voltage representing the cold-junction temperature
*            | | Vtc+ =
*            | | | Vtc- =
.SUBCKT TC_K 1 2 3 4
E_TJ 5 0 VALUE = { IF(V(1) <= 0,
+   0.000000000000E+00          +
+   0.394501280250E-01*V(1)     +
+   0.236223735980E-04*V(1)**2  +
+  -0.328589067840E-06*V(1)**3  +
+  -0.499048287770E-08*V(1)**4  +
+  -0.675090591730E-10*V(1)**5  +
+  -0.574103274280E-12*V(1)**6  +
+  -0.310888728940E-14*V(1)**7  +
+  -0.104516093650E-16*V(1)**8  +
+  -0.198892668780E-19*V(1)**9  +
+  -0.163226974860E-22*V(1)**10 ,
+  -0.176004136860E-01          +
+   0.389212049750E-01*V(1)     +
+   0.185587700320E-04*V(1)**2  +
+  -0.994575928740E-07*V(1)**3  +
+   0.318409457190E-09*V(1)**4  +
+  -0.560728448890E-12*V(1)**5  +
+   0.560750590590E-15*V(1)**6  +
+  -0.320207200030E-18*V(1)**7  +
+   0.971511471520E-22*V(1)**8  +
+  -0.121047212750E-25*V(1)**9  +
+   0.118597600000E+00*EXP(-0.118343200000E-03*(V(1)-0.126968600000E+03)**2) ) }
E_TR 6 0 VALUE = { IF(V(2) <= 0,
+   0.394501280250E-01*V(2)     +
+   0.236223735980E-04*V(2)**2  +
+  -0.328589067840E-06*V(2)**3  +
+  -0.499048287770E-08*V(2)**4  +
+  -0.675090591730E-10*V(2)**5  +
+  -0.574103274280E-12*V(2)**6  +
+  -0.310888728940E-14*V(2)**7  +
+  -0.104516093650E-16*V(2)**8  +
+  -0.198892668780E-19*V(2)**9  +
+  -0.163226974860E-22*V(2)**10 ,
+   0.389212049750E-01*V(2)     +
+   0.185587700320E-04*V(2)**2  +
+  -0.994575928740E-07*V(2)**3  +
+   0.318409457190E-09*V(2)**4  +
+  -0.560728448890E-12*V(2)**5  +
+   0.560750590590E-15*V(2)**6  +
+  -0.320207200030E-18*V(2)**7  +
+   0.971511471520E-22*V(2)**8  +
+  -0.121047212750E-25*V(2)**9  +
+   0.118597600000E+00*EXP(-0.118343200000E-03*(V(2)-0.126968600000E+03)**2) ) }
E_TC 3 4 VALUE = { (V(5)-V(6))/1000 }
.ENDS
The following users thanked this post: T3sl4co1l
